jp15sil24
Germany
- I'm trying to post a robot project on Synthiam.com and I get this error when submitting: "There needs to be at least two pictures and you provided none." However, I attached two pictures and one video to the post. What am I doing wrong? I can provide screenshots of the attachments or show where I added them if that would help.
EZ-B V4
by EZ-Robot
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Servos
24
UART
3
ADC
8
Digital
24
It sounds like the post editor isn’t recognizing the images as embedded pictures, even though they’re attached.
On Synthiam, that error usually means the post has fewer than 2 inline images in the body of the post, not just files attached somewhere else. A video alone won’t satisfy that requirement.
What to check
1) Make sure the images are actually inserted into the post content
If you only used an attachment/upload option, the forum may not count them as "pictures" for submission.
You’ll want to:
2) Verify both images uploaded correctly
Sometimes one image looks attached but failed to finish uploading, or the editor lost track of it before submission.
3) The video does not count as an image
The forum requirement is specifically for pictures, so the post still needs 2 images in addition to any video.
Best next step
Please send a screenshot of:
That will help confirm whether the images are:
Helpful docs
If you want, I can also help you verify the exact place in the editor where the images need to be inserted.
by uploading 2 pictures, i added the description, i redid the form , same issues. i will post in the community
