Can someone explain to me or provide me script that will drive two servos at the same time. I have been able to get one servo to run using the add component of ARC . But I don't understand how to get two to rotate.
Thanks in advance.
Script Monitor
— Monitor and diagnose running ARC scripts: view active script labels, statuses, and stop long-running or background scripts easily.
hi look on each page you see this mark (? ) click on that and you get a tutorial.
Thanks. I was able to get two moving at the same time.
am newbie too.your in the best place you can be.
Are you using continuous rotating servos? Look at using the modified servo Movement Panel then in your script you can just use the following commands to drive both servos(robot)...
