PWM Servo Feedback (ADC) icon PWM Servo Feedback (ADC) — Add ADC positional feedback to hobby PWM servos via minor mod to EZ-B/Arduino; enables real-time position readout, calibration and puppet mirroring Try it →
Need Help Testing The Elechouse Tlg10ua03 Uart-wifi ?
Need Help Testing The Elechouse Tlg10ua03 Uart-Wifi ?
After Midnight Thursday, 14 March 2013
Good Morning EZ-Robot.com Hardware Team !
 Last week I received my ElecHouse UART-WiFi Kit, and got it Connecting to my Home Router with help from Robot-Doc, who  led me to the TLG10UA03,
ElecHouse UART-WiFi
 I have attached my Screenshots and Test Procedure, "13-Mar-2013 ElecHouse WiFi UART Serial Terminal Loop-Back Test.doc", and my ARC File of the same name.
 I am using DJ's New Serial Terminal within ARC; seems to WORK GREAT, but I need to LEARN MORE on its proper use ?
 My Question is, Exactly Where Do I Loop-Back the WiFi Module; I tried Tx-to-Rx with No Success ?
Thank You All & Best Wishes,
[email protected], 602-246-1246(H)
13-Mar-2013ElecHouseWiFiUARTSerialTerminalLoop-BackTest.zip
13-Mar-2013WiFiUARTSerialTerminalLoop-BackTest.EZB
#113
ok but definitely not what I need since I use this robot remotely to check on my cats...:D I cannot afford a system that needs to be power-recycled to work properly. Thank you anyway.
By the way... I must have done something wrong again with my new TLG10UA03... I can access it through the config app but cannot make any modification or restore. Anyone knows where to find the firmware ?
Best.
#114
I hope I am not throwing good money after bad, but I just ordered one of these https://www.rovingnetworks.com/products/RN174 (specifically, the RN174U since I have the antennae from the fried Elechouse board I can use with it). At $79 + shipping, it sure isn't cheap. You can get just the chip for less, but it is surface mount, so a lot more work and parts to make it usable which I am not ready to do. This dev board should be just about plug and play.
I'll let you all know how it works.
@thetechguru I was looking at rn172 to,i will wait to see how you make out before i buy one good luck
#116
I'm still holding out for the Tlg10ua03 but the issue with not enough current is what's stalling my progress. Hopefully I'll get a solution to that soon - I'm yet to try it while running from the 2S LiPo due to limited time.
#117
This device sucks... There is a low current device on the market made by Saint Smart, a wifi Shield for Arduino that theoretically should be compatible with EZB. According to those who successfully set it up on their project it really takes very low current. But I couldn't even get it to run with standard arduino wifi webserver programm and I could not access it through serial/usb either so I returned it. I think we should all look forward to finding a device explicitely sold for its low current consumption.
#118
Cost is a big issue I like to based solutions on though. While it's not always just because it's cheapest, or because I can't afford anything more expensive I'm driven by helping as many others as possible and that includes those who are on tight budgets (naive people, I was one once before I started building robots). So I will continue to pursue this option and find a solutions (or try to) for the power issue. I have some ideas.
#119
@Rich, I am pretty sure you'll be able to get it working with alternate power. Robot-Doc has repeatedly reported success with that board. If I hadn't blown mine up, I would still be trying, but since it is problematic, I figured I would go another direction and try it.
The Roving Networks boards can be had for less. $29 for the chip, and I saw a developer board at RadioShack yesterday for $8 that the label said worked with surface mount chips and minimal soldering., so if you are skilled with a soldering iron, it is competitive to the Elechouse. I decided to go more plug and play for now, but if it works well with the developer board I ordered, those on a budget would have some options.
#120
I'll have to look in to that one sine my hatred for soldering has turned to a near love now.
My plan is to find a 3.3v regulator that'll do the job if powering the ezb with the lipo doesn't work. I need more time in the day though, another 20 hours would be nice!
