Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
#1   — Edited
Under servo there is one, and under movement panels there is another
under servo, as many as you need can be added = auto-position movement panels
After you select a servo, you can also pick a connection - connect 0 - 4
EzAng
Add the Auto Position non-movement panel.
Arc -> project -> add robot skill -> servos -> auto position
If you think about it, you’ll realize why there logically can only be one movement panel. Check the manual on what a Movement Panel is as well
Twitter
Aggh OK I did not know that existed.  Thanks EzAng That is exactly what I was looking for.  OK not a required feature any more :-) Time Space saved again.  Please close request.
This was moved into a question
Thanks Jeremie,
Your community post was liked by 'Jeremie'.
