Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Micro Hdd Servo Dimension
Hello everyone.
Can someone confirm the physical size of the Micro HDD Servo?
The product page lists - Width 3.0 cm Length 3.0 cm Height 1.0 cm which seems odd.
I wanted to make a cad file of it so. Also if anyone has done this please pass it along.
Thanks Tony
Just bumping this.
width 20mm Length 40mm Height 40mm Just got some in and that is the measurement I got. with a gauge it is width 19.88 length 40.74 Height 38.32
@nallycat... wrong servo dude... @3dGuy wants to know the micro HDD servo size
Height: 35.16mm (including top of the servo horn).. 31.16mm to the body top Length: 29.42mm (not including screw anchors, body only) Thick(width): 13.81mm
more or less Richard's results:
width: 13.80 mm
Length: 29.40 mm
Heigth 1: 27.60 mm
Heigth 2: 31.00 mm
Height w/horn: 34.90 mm
distance horn <-> side: 22.90
I just got these HDD ez-robot servos in the mail today here are my measurements of just the plastic body not the spline or the attachment screw points
@nallycat... Again the OP wants the dimensions of the micro HDD servo not the regular full sized HDD servo in which you are measuring...
