Troy
— Edited
It's.It's.Omg It's A Cylon
It's now only a matter of time before they enslave us.
Thanx!
Programming With Pictures
— Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots.
hahahaha very funny.
Ya, I feel the pain. That's exactly what I would expect the robot to say. LOL!
if you dont start the video,look at his right foot,doesn look real robot. do i must say am feeling little sad for the robot.
It's not fake - however, an infinite amount of time with an infinite number of monkeys using an infinite number of typewriters will create the script to Hamlet...
To summarize, you can spend a month filming the robot attempting to perform the same routines and chances are, if you're coding is right, it will do it one or two times. 1,000 takes and 1 final cut
Lastly, you can tell in the videos that there is no navigational way-point. The processing capability and physical engineering requirements are designed for stability, not navigation. That being said, it's clearly a huge leap forward in gait stability and recovery. Once this technology is able to compensate for directional stability (meaning, recovering and still being able to navigate a pre-determined path) it will be awesome.
What i mean by this is if you had a pathway consisting of boulders/rocks/rough terrain, the robot's primary function is to maintain stability, not navigate the pathway. So the robot will be twisting and rocking from side to side, which does not provide any course correction or way-point navigation.
Still, it's great to see robot videos like this - specifically when they're viewed by people like my mother, who would have traditionally never seen it. It means robot's are becoming a little more mainstream - that's great news!
dj good explanation.so its all about stability.in his head i see something turning, is that similar like david cohran use the lidar?
i think robots are getting better to with things like walking,speech,recognition. it took me some time to get used how they are build or look. now i now they are build the way what he needs to do.
It's awesome to see such advancements lately in the robotic industry. The reflex ability is really something special. That balance is better than me on my airwheels a3 that's for sure. This next decade is definitely going to be something special. Thanks for the share!
What I find interesting about the gait is that it doesn't seem to shift it's weight from side to side to walk. Just lifts the leg and places it forward. I wonder if it can balance on one leg like that for an extended period? Or is it actually doing what humans do when they walk, a series of controlled falls.
