example
This is ok $BasePath = "G:"
but this gives error
$BasePath = "G:/"
it is because of the / , im asuming is being used as an escape char in Ez-Script.
is there a way to escape this?
DHT11 Temp & Humidity Sensor
— Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables.
example
$BasePath = "G:/"
This
$BasePath = "G:\"
Also resulted in error.
Thanks guys.
No problem. I guess the outcome is that this is a limitation in EZ-Script and an alternative method is needed.
P.S. Thanks for the credit, you're number 250
maybe it is messing up because you misspelled weather in wather.rss
...or it's a typo when he wrote his post (#6)....
ya the wather weather was not relevant. The out come was just the EZ Script does not allow the \ character at the end of a string.
this can work to remove the extra space left at the end if you really wanted the \ at the end of the first variable
have any of you guys figured out how to print a forward bracket? i.e. "(" the backslash in front works for printing """ but not the (
