Remote UI Client icon Remote UI Client — PC Remote UI Client for ARC enables remote robot control via customizable multi-page interfaces from other ARC instances. Try it →
Irobot 530 Quick Advice
Hi guys.
I am currently looking at a Roomba IRobot 530 on a popular auction site I want to get. I don't wish to appear rude but I need some quick advice before I place a bid, as the clock is ticking. eek
Does the 530 have a comms port to connect the EZ-B4?
Is the 530 compatible with the EZ-B4?
I've never had a robot vac so it's all new to me. I know DJ does reference the iRobot but there's no mention on models.
Cheers.:)
#33
I have some more advice for you. If you plan to use a factory cable, unscrew the two little screws and take it apart and check the wiring. I had a brand new factory cable and it came in very Shotty. It blew up my 530 and I had to get another motherboard because of it. If you inspect first, then you will be happier later on.
my 2 cents.
#34
@ Steve G, for what it's worth I just ran jumper cables from roomba's power pin (actually I gave up on the PS2 connector and ran jumpers to all the pins) to a stepdown converter @ 8.5V. I run the old EZ 3 and wireless cam all through the Roomba's power to the stepdown. Works great. But do this at your own risk
#35
@MovieMaker.
Thanks for the heads up. I'm actually using a mini Din plug I had laying around and soldering my own wires. Thanks for the advice though.
@pacowang.
Thanks for sharing what you have done and the advice. Cool idea powering the EZ-B3 from the Roomba's power supply. I think I'll stick to an external LiPo to power my v4 though. I just liked the idea of convieniance to power a small remote off the 530 so I wouldn't have to add a manual power switch.
#36
@Richard and Doc.
I thought I would dive in and hook up my 530 to the EZ-B. I downloaded your project first (Richard), but after I hit "init", nothing worked. So I tried DJ's Roomba project and I got some temperamental movement. I got nothing at first then it burst in to life moving forwards, but wouldn't stop, turn, anything. After I picked it up it stopped and I tried again. This time I hit turn left which it did, but pressuring stop or anything else had no effect.
Any ideas what's up?
#38
I am using UART port 1 which sends data (to the Roomba) on the EZB digital pin 5... I just tried it... it works no problem on my 530 and 650 Roombas...
#39
@Richard.
DOH, I had a Homer Simpson moment, sorry. I looked at the UART scripts to check what port you were using and saw it was port 1. So I connected it to D1, not UART 1 (D5/D6), took a time out and realised my mistake blush. It's all working now. Now what I need to do is figure out how to turn on the sensors, auto cleaning mode, and seek and dock.
#40
@Steve... That's pretty easy... I don't have time today, but remind me tomorrow and I will shoot you those commands....
