Train Vision Object By Script icon Train Vision Object By Script Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Import Respeaker USB Mic Array DOA Information To Ez-B
I am going to buy a Seeed ReSpeaker USB Mic Array.  I would like to send ReSpeaker sound Direction Of Arrival (DOA) information to Ez-b.  If can get it into Ez-b I can write a script that will send instructions to my robot Max and allow Max to point to the person speaking.  How would I go about getting this ReSpeaker information into the Ez-B script?
Here is the link to information concerning  Seeed ReSpeaker USB Mic Array.  I will most likely need direction on how to get it to work with Ez-B.
wiki.seeedstudio.com/ReSpeaker-USB-Mic-Array/
If link does not load.  Right click link and select the Go to wiki.seeedstudio.com/ReSpeaker-USB-Mic-Array/.  That should let you see the information.
Thanks Ellis
EZ-B v4/2 robot controller: dual Cortex ARM, Wi-Fi, audio/video, 24 servo/digital ports, I2C/UART, camera and Synthiam ARC control for custom robots
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
Script by Synthiam
#1   — Edited
That's a usb speaker. It won't connect to any ezb. It's made to connect to a usb host, which is would be a windows PC. You can use a windows pc running ARC. Because the hardware would need to know where the voice is coming from, you'd have to access their SDK or API. You can wrap the sdk or api in a skill control plugin to work with ARC.
PS, that link won't load because the seed website doesn't have an SSL certificate or HTTPS server. They have no security on their web server. Be very careful when you use that chinese company's website. Do not login or create accounts because it is not a secure website. The way to view that website is to replace HTTPS with HTTP in the url
I was planning to have information from the ReSpeaker fed into Windows 10 pc.  I didn't know how to get that information readable to ARC.  I guess this device is not usable.
It would be usable if a little program (skill control) was created for it. If there's a library available, it would be easy to whip something up. I could even do it for you. Just haven't come across anything very trustworthy on their blog. They use a hacked program to force driver installations and fool windows. There's a lot of sketchiness going on with that product.
'd recommend using the solution i provided, which is already in your windows 10 pc... a sound card microphone input: https://synthiam.com/Products/Controls/Scripting/Sound-Movement-16110
I have given up on the Seeed Respeaker after reading your recommendation.
I am going to try the Sound-Movement idea you recommended.
Also, I think there may be problems with my Sound Sensors.  They do not seem to be working as they should.  In analog I get very little change on the ADC Graph unless I blow hard into the sensors microphone.  Then I only get 1 volt variation on the Read ADC intermittently.  Are there differences in these sound sensors?  Is there a good sound sensor for this application using an Ez-B?
Thank you so much for helping me.
I have a sound sensor - maybe tonight I’ll try it. It might work better with a capacitor to hold the voltage higher for longer. Maybe Jeremie has a good idea
I never thought of that.  That is a great idea.
The analog power pin is only 3.3v... If your sound sensor needs 5v that could be the reason it isn't working....
