Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
How To Use Hc-Sr04 Sensor As A Ping Sensor
its fairly easy using a pnp transistor and 10k resistor on the trigger pin you use a 10 k to gnd and then emitter tied to trigger pin ,collector gets v+ and base gets another 10 k tied to digital pin and the same digital pin tie the echo pin ,need to first pull digital pin high for more then 10 us and then low to read the echo bounce
