Notepad icon Notepad — Notepad for ARC: store project notes and connection details in a themed window Try it →
Help With Wowwee Roboquad
Hi, I just got the RoboQuad from ebay and I started to follow the video on connecting the EZ-B to it, but when I opened the head it looks different then the video. The board says G7303-3A. Can someone help in wiring it up? steve3624
#65
I know it its frustrating to run across the 4th version of the roboquad that is not directly supported , but why not ditch the original sensors and brain completely? In the eye sockets place a ultrasonic range finder or a Sharp IR if you want or you could put a maxbotic single sensor range finder in one eye socket and EZ wireless Cam in the other eye socket. The motors could be controlled based on time with a Darlington switching transistor or you could do what I would and swap them for 4 high torque servos from the Ezrobot online store. The shell is awesome , just keep LEDs , record sounds if you want to playback after all your mods are done:). There's lots of power in ezb and its control software ARC , you can do it;) - Josh S
#66
Well, that's what I'm working on but the time commitment and learning curve is not EZ; it's intermediate robotics. I hope not many more people experience this frustration buying the EZ-B and then experience immediate disappointment that the RoboQuad is only partially supported and feel somewhat mislead. As far as I can tell there is no specific way of buying the supported version RoboQuad. If any one knows how, I would like to buy another that I can immediately hookup to the EZ-B....
#67
I admit I was quite frustrated at first but that quickly passed as I popped the EZ brain on a Boe bot frame I had. Provided lots of fun for me and my 8 yr old. Then we pulled out the hot glue and put together a 4 axis robot arm in just a few hours and thanks to the frames sequencing it was easy peasy. I came to the conclusion that building a 18 servo Hexapod was the best use for this controller. It could easily control the roboquad with IR LED if or when someone deciphers the output of the remote. So far so fun I will add another board before long to teach some aspects of micro controllers in my kiddos class.
#69
Hello, I emailed EZ-Robot to find out the status of D.J. and my RoboQuad and the remote leversofpower sent him. I am happy to see he is fine, this is what I got back. "DJ is doing more than OK. We are working on some new really exciting technologies. One of them the features he's working on requires a lot of testing using your RoboQuad. If it's alright DJ would love it if he could hold onto it for another month or two." So maybe soon all of the people following the thread might have an answer as to how to connect their EZ-B to their RoboQuad.
#70
if some one could catch the ir transmissions and post them we might be able to come up with something using the "sendserial" command. but first we need to know how to wire up.
I know them. A friend got them for me. I will see if I can find them.
RoboQuad Header is $6. It uses a 12 bit 1200 baud protocal with no stop bits. It wants about 500 ms before retransmission
Stop=$600
Walk_Forward=$601
Right_Crab_Walk=$604
Left_Crab_Walk=$603
Left_Crab_Four_Steps=$623
Right_Crab_Four_Steps=$624
Backward_Four_Steps=$622
Walk_Backward=$602
Forward_Four_Steps=$621
Rotate_Counter_Clockwise=$60a
Counter_Clockwise_Four_Steps=$62a
Rotate_Clockwise=$609
Clockwise_Four_Steps=$629
Head_Up=$681
Head_Down=$682
Head_Clockwise=$689
Head_Counter_Clockwise=$68a
Top_Left_Shuffle=$605
Top_Right_Shuffle=$606
Bottom_Left_Shuffle=$607
Bottom_Right_Shuffle=$608
Left_Strafe=$625
Right_Strafe=$626
Left_Turn_Roll=$627
Right_Turn_Roll=$628
Burst=$64a
Single_Shot=$649
Stomp_Walk=$641
Left_Legs_In=$643
Left_Legs_Out=$683
Left_Forward_Leg_In=$645
Left_Forward_Leg_Out=$685
Left_Backward_Leg_In=$647
Left_Backward_Leg_Out=$687
Right_Legs_In=$644
Right_Legs_Out=$684
Right_Forward_Leg_In=$646
Right_Forward_Leg_Out=$686
Right_Backward_Leg_In=$648
Right_Backward_Leg_Out=$688
Program=$614
Play_Program=$615
Program_Delete_Last_Step=$634
Erase_Program=$654
Scan_Left_For_Object=$632
Scan_Right_For_Object=$652
Smart_Scan=$631
Approach_Nearest_Object=$650
Escape_Walk=$690
Toggle_Activity_Level_1=$6d0
Toggle_Activity_Level_2=$6d1
Toggle_Activity_Level_3=$6d2
Toggle_Aggression_1=$6c0
Toggle_Aggression_2=$6d0
Toggle_Aggression_3=$6e0
Toggle_Awareness_1=$6e0
Toggle_Awareness_2=$6e4
Toggle_Awareness_3=$6e8
Leg_Reset=$620
Full_Reset=$640
Volume_Up=$695
Volume_Down=$694
Guard=$630
Sleep=$680
Toggle_Autonomy=$610
Toggle_Sensors=$635
Twitch=$651
Surprise=$642
Wave=$696
Dizzy=$655
Attack=$653
Roar=$633
Aware_Stance=$692
High_Stance=$691
Aggressive_Stance=$693
Dance_Demo=$616
Movement_Demo=$636
Leg_Check=$656
