The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Resolved Resolved by Rich!
Help With Variable Input And Output For Faces
Well, I was working on a surprise for the group, but I need some help first. I have a nifty multiple face detection program working in C#.net. So far I have it programmed to recognize my face, DJ Sures, Sarah Connor and Alan Turing. Minus my face, I figure all EZ-robots should know who the other three people are.
My C# app generates a change in variable and displays this in a label in the form to show who's name it is for the face it sees. For this to be useful for integration with ARC I need to get this variable out of my app an into ARC.
I see two ways to do this, one is write the data to a .txt file, have ARC keep checking this text file, read the text file, if the text changes then act on that. - This seems sloppy and slow.
Option 2 seems better which is to use TCP/IP and Telnet. I've viewed the tutorial here: https://synthiam.com/Tutorials/Help.aspx?id=159 and I fundamental understand it. I can connect to ARC with Telnet. I I'm sure I can tell my C# app to send telnet data. What I can't wrap my head around is how to I make a script in ARC to look for an incoming variable on the TCP/IP port such as "$Face_Name" so that ARC can then act on that data?
Can someone help me with that? Or is there a 3rd option I'm not thinking of yet that would be better? I'm looking forward to get this figured out so I can share my app with the group.
Thank you! -Justin
That is so cool of you. Way (way way way) down on my todo list was a plan to start learning OpenCV and build something similar, but if you have done the work already, it is one less thing I need to do:)
You rock Justin.:D People have been wanting multi facial recognition for long time. I haven't played with facial rec much but, I not gonna lie and say I won't be checking this out.;)
If you can accomplish this dude... Yes, you rock:D
Man! That is sweet! I would love to have that capability on my sentry bot.
Brazil
Just can't wait to try it! How do you plan to share that? Will us be able to download it From here ? Thanks!
I'll upload it on my site and make a project page here with the link, info and so updates can be posted. I think everyone will like it and hopeful help me improve it with your input and feedbacl. I got the ARC communications side straitened out but now I'm having issues issue sending data from the C# app side. I posted another thread with my issues for that.
#15
Cha-Ching! I found the issue for the c# I needed use Tutorial 52 for Scripting for the correct example of how to connect via TCP and send a variable. It all works. My App sees faces and you can add new one, opens a port to ARC, sends the name of the face seen, ARC script gets the variable and can act on it, in the demo I have it speak the name.
Soon I'll upload it with source code and start a project page. I'm going to call it EZ-Face.
Thank you Rich and DJ! I'm looking forward to hearing the groups thoughts on it.
#16
I think this is awesome! When you get everything worked out, could you do a tutorial to show us how to do all this? This is so neat! Thank you so very much for this. This is a giant step forward for everyone.
