ZAMA Emotion Model icon ZAMA Emotion Model — Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors. Try it →
Resolved Resolved by Rich!
Help With Variable Input And Output For Faces
Well, I was working on a surprise for the group, but I need some help first. I have a nifty multiple face detection program working in C#.net. So far I have it programmed to recognize my face, DJ Sures, Sarah Connor and Alan Turing. Minus my face, I figure all EZ-robots should know who the other three people are.
My C# app generates a change in variable and displays this in a label in the form to show who's name it is for the face it sees. For this to be useful for integration with ARC I need to get this variable out of my app an into ARC.
I see two ways to do this, one is write the data to a .txt file, have ARC keep checking this text file, read the text file, if the text changes then act on that. - This seems sloppy and slow.
Option 2 seems better which is to use TCP/IP and Telnet. I've viewed the tutorial here: https://synthiam.com/Tutorials/Help.aspx?id=159 and I fundamental understand it. I can connect to ARC with Telnet. I I'm sure I can tell my C# app to send telnet data. What I can't wrap my head around is how to I make a script in ARC to look for an incoming variable on the TCP/IP port such as "$Face_Name" so that ARC can then act on that data?
Can someone help me with that? Or is there a 3rd option I'm not thinking of yet that would be better? I'm looking forward to get this figured out so I can share my app with the group.
Thank you! -Justin
WaitForChange is the command you are looking for.
Give me a minute or two and I'll knock up a quick script example for you.
# Make sure the variable exists and is reset
$FaceName = "null"
# Make an endless loop
:loop
# Wait until the variable changes
WaitForChange($FaceName)
# Script commands to be run on change of facename variable
# Loop back to the start
Goto(loop)
It's that simple:) No sleep should be required since the face probably wont change too quickly.
Ok, I added that as a script, ran it and I get Error in line 2 variable not defined $FaceName
Updated the script a little;)
All variables need to exist before using them in commands otherwise it'll throw that error. I usually define all variables as "null" or as 0 in the init script.
And yes, I changed it before you posted as I saw the potential problem:)
@JustinRatliff
This is an awesome thing.... How are you adding faces to the recognition engine? Will it be something users will be able to easily (or not easily, but without C# programming skill) do?
I would love to have my robot recognize me, my wife, my cat, and a couple of friends, and treat everyone else as stranger (or when in "security mode" potentially hostile).
I also love your choice of default recognized faces. I would suggest adding Issac Asimov.
@Rich - You Da MAN!
I'm getting so close I smell it. Thank you Rich!
@thetechguru It's an application that runs on its own. I am making it to share with everyone - anyone should be able to use it as a standalone app. If I get lucky I'll have the very pre-beta version ready to share tonight or tomorrow.
