Help Getting Started With Ez Robot Jd
Hey All,
Just got my EZ Robot JD! I am not a robots expert - actually bought the JD to do a review of it for our viewers on our YouTube Channel. Need a little help...
Watched the videos, but some things don't match up. Trying to power it, but video shows battery pack and I have AC Adapter. So, I think I plugged it in the best way I could - see the photo. Red and Green light go on the balance charger. Left it for a few hours. Unplugged balance charger, flipped switch on and nothing.
Video says a light will come on and play a sound. Also says a WiFi network should appear on PC. None of that happens. Really seems like no power to the unit at all.
Anyway to test if the unit has any power? Is there really a light on the body when you power it up? I don't see one Should the Red and Green light ever go off when charging? Mine doesn't Should initial charge take more than 2 hours?
Would love some help so I could get started.
Thanks in advanced!
Hi Dad!
We will have dozens and dozens of new videos and tutorials coming online in the upcoming days - so stay tuned! It's too bad you weren't doing the review in 3 weeks, because we will have video guided walk-throughs on the whole process:)
The LEARN section is actually being entirely re-written by Chrissi - and will include incremental tutorial lessons with progress meters and even awards for achievements! That will be online within the next 2 weeks:D
  1. On the blue adapter, you will see the words "Balance Charger". It is actually the battery charger for the battery. The battery is inside of the body, and you have it connected correctly. Red light is the power to the charger. Green light means it is charging. When the green light goes out, the battery is charged.
  2. You do not need the EZ-B installed for the charger to operate. The battery is actually in the body of JD
  3. Make sure the power is turned off when charging. The switch has a 0 and 1. The 0 position (Which it currently is in your picture) is off.
  4. To assembly JD, you will download ARC to your Windows computer
  5. Select the OPEN button in ARC
  6. Select the JD project in ARC
  7. Press the LOAD button to load the JD Project in ARC
  8. After the project loads, it will ask if you wish to see assembly instructions. Answer YES
  9. Follow through the assembly and pay attention to the servos and how they install. If you install the servos backward, the robot will do funny things:) It's like installing your joints backwards, now that would be funny!
Get that far, and if you still need help.. let us know:)
There is a battery pack inside the body. you are charging it now.
ARC has step by step instructions on how to put the robot together.
launch ARC, choose file then open, then choose examples and then open the JD example.
It will ask you if you would like to see instructions on how to put him together. say yes and you will be way ahead.
Hey,
Thanks so much for the quick replies...
DJ - if more coming soon, happy to wait to do the review. For now just want to make sure I can get the robot up and running.
Answered most of my questions, just a few follow-ups...
  1. Is there a light or sound on the power pack that should go on when you turn it on? As I think I have been charging it correctly, just looking for an easy way to see if it is working.
  2. How long does it take to charge the battery?
If the answer to Question 1 is no - then I will follow the instructions to assemble the robot and test him that way.
Thanks again.
When charging the battery there will be 2 lights on while charging. When it is finished charging only one light will be on.
When you flip the switch after the battery is charged on the robot, you will hear "Welcome to EZ-robot revolution" with some other stuff that is kind of important. You will see a light go on on the EZ-B which is where all of the cables will plug into from the servos.
It takes about 1.3 hours to charge the battery from dead to full charge.
Hey D.Cochran,
Thanks for the info. Unfortunately think I have a problem with my power pack. I have had it plugged in for hours - both red and green lights stay on. The green charge light never goes off. After a few hours, have tried unplugging the charger and turning it on - nothing happens. No lights, no sounds, no Wi-Fi network.
Any ideas how to test if it is the battery?
Thanks for all the help.
without removing it from the body, I dont know. Is the charger (blue part) getting warm?
If you have a multimeter you can check the voltage on the balance plug of the battery. Positive probe on one side, negative probe on the other (nothing on the middle pin) and it should give you a voltage of something over 7v (hopefully).
If you don't mind spending a few $ you could always pick up one of these, plug it in the balance port on the JD and it should tell you the voltage of the batteries cells.
Additionally, when you switch the switch on the EZ-B itself should make some noise, a light should come on on it and it should welcome you to the EZ-Robot Revolution. It's unlikely but the speaker may have become disconnected on the EZ-B, if you get no sounds you can try and test the voltage across a VCC and Ground Pin on the top (red and black pins down the side), look in the small gap by it and check it is a digital port (it'll say D0 or D1 or something up to D24), it should give a voltage of over 7v.
I know my Six battery seemed to take forever to charge, the green light never went out until I switched Six on while charging. Not sure why this was but it's worked flawlessly ever since.
There are other things we can also check too but start with the above and we will take it from there:)
I think @Rich has something here... I have a few so called "smart chargers" that once in a while will fail to switch to trickle charging mode once the battery is fully charged.... Disconnecting and unplugging the charger seems to fix it (a reboot or recalibration in a sense I guess)....
