Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
thats awesome.micro HDD love it.
Ironically i have never had the old micro servo burn out... But so far the first batch of the new regular hdd servos i have 4 out of 20 I bought stop working within minutes... I haven't used the remaing 16 but i am not that hopeful... Early adopter is a rough road I guess... I want to buy more if they actually work now... I understand growing pains but i want to have confidence again with the hdd servos...
RR
any reason why they burn out? or stop working.
@RR
Is there anything out of the ordinary you are doing with the HDD servos? I'm puzzled, I haven't seen any HDD servos fail myself, beside potentiometer issues. Are you are vibrating them extremely quickly back and forth in your code? What kind of load are they under?
Yeah would be good to know before i place an order for 15.
@Jeremie... Absolutely not... I am using it in a claw for a robot that used to have an old buzzy Hitec hs645 in it... It lasted years with the hitec... The symptoms are as follows..
All 4 servos did the following... sometimes under load, sometimes not... pure random
  1. the servo begins to only want to move in one direction only... e.g. upper or lower positions like for example 110 to 180... but won't respond to anything less that say 110... These are just example figures it could and has been vise versa...
  2. After that (a few minutes it won't move at all and the magic smoke gets released..
  3. RIP servo
Battery used 7.2V niMH Claw used as in picture
HDD servo #5 is now in this claw...
