Is it possible to connect an FT232RL USB-to-serial adapter to an EZB controller using the UART TX, RX, and GND pins, instead of connecting to the camera port with those same pins? I've attempted this setup without success. I assume there's a difference between the UART pins and the camera port pins. I'm utilizing the Connection robot skill in this setup.
afcorson
FT232RL To EZB UART Connection
EZ-B V4
by EZ-Robot
Servos
24
UART
3
ADC
8
Digital
24
EZB Connection
by Synthiam
Serial Terminal
by Synthiam
PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex
Short answer: Yes - but only if you wire it as a TTL (3.3V) serial link to the correct EZB UART pins, with a common ground, and the FT232 module set to 3.3V I/O. Do NOT assume the camera connector pins are identical to the EZB UART pins.
Below are the recommended checks, correct wiring examples, and troubleshooting steps.
References:
If you still have trouble, tell me:
I can then give exact wiring for your board and a stepbystep test to confirm communication.
Athena said yes because the question focused on simply connecting a USB UART to any EZB UART port, without explaining why. Athena, the original poster is asking whether the EZB can be connected to any UARTS other than the camera port to avoid using WiFi to control it. The answer is no, you cannot. The Camera port is the only port you can use to control the EZB via the ezb protocol instead of Wi-Fi, due to its internal wiring.
You might be asking because you would like to use the camera and the ezb at the same time over a UART connection, rather than Wi-Fi, but that isn't possible because they're two different streams. Even if another uart could be used for the ezb protocol, the camera would still need its own uart to the PC because they're seperate streams. You see, networking (TCP) uses ports, and each port can have many connections, so that you can do many things at the same time. Where UART is a single stream of bytes, and you can't do many things at the same time. Well, without getting into a very complicated discussion of protocols, we'll keep it at "you can't".
The solution you're looking for is to use TWO USB UARTs to connect to the PC, one for the EZB and one for the CamCamerar. You can use a USB camera and get better resolution, etc...
Short answer: DJ_Sures is correct for the common use-case. You can wire an FT232RL to the EZ-B’s general UART pins (D5/D6, D18/D19, etc.) for TTL serial communications with whatever device is on that UART - but you cannot replace the EZB "host"/ezb protocol USB serial interface with just any D# pin. The ezb protocol that ARC expects over a COM port is exposed on the EZB’s host/USB serial path (camera/expansion UART), not on the arbitrary D# UART lines. That’s why the camera/expansion header is the only port you can use for an ARC <-> EZB COM (ezb protocol) connection instead of WiFi.
Details and recommended options
Why this matters
Practical options / solutions
How to test (safe checklist)
Useful links
If you want, tell me:
I’ll give a step-by-step wiring + ARC Connection/Serial Terminal test for your specific setup.
I thought that was the case, otherwise other people would avoid using of the camera port for a USB connection. It means I have to install another camera in my InMoov robot. Taking the EZ camera out of the eye involves too much dismantling.
You’re right - removing the EZ camera from the InMoov eye is a pain. You don’t have to; there are other practical ways to keep the eye camera and still get reliable control of the EZ-B. Below are the realistic options, what they require, and stepbystep actions you can take. I’ll also ask a couple quick questions at the end so I can give exact wiring / ARC steps for your situation.
Options (best least intrusive)
Other wired-ish alternatives
Useful references
Quick checklist / decision guide
I’ll give stepbystep wiring and the exact ARC Connection / Serial Terminal test for whichever option you pick.
I have just removed the WiFi method of connection for my InMoov robot. I find a SBC gives me USB ports for a microphone, touchscreen and camera as well as Bluetooth for an XBox controller. Most important of all, I have WiFi for internet and can use ChatGPT, previously not possible when WiFi is used for the connection.
Nice - that’s a good move. Running ARC on an SBC with the EZ-B on a local USB/serial link gives you the PC resources (mic, touchscreen, higher-res webcam, internet/ChatGPT, Bluetooth controllers) while freeing WiFi for internet. A few tips, checks, and next steps so your InMoov runs reliably.
Quick summary of what to expect
Step-by-step (USB EZ-B SBC ARC)
Quick ARC script checks (examples)
(Place these in a Script control or run from Developer Console in ARC.)
Notes & gotchas
Questions so I can give exact step-by-step for your setup
If you tell me OS + how EZ-B is connected, I’ll give the exact terminal commands to find the device node and the ARC Connection settings to use (and a Connection Established script example to safely initialize servos).
You can connect the ezb v4 ezrobot camera to a usb UART device. the camera is uart as well
