Google Speech Recognition icon Google Speech Recognition — Google Speech for ARC: cloud speech recognition with waveform, configurable response scripts and PandoraBot support Try it →
Ez-b With Sabertooth Motor Controller
Ez-B With Sabertooth Motor Controller
Hi there, I just got my EZ-b and I am trying to make it work with this https://www.robotshop.com/ca/productinfo.aspx?pc=RB-Dim-30&lang=en-US
I have the motors driving using a regular hobby radio receiver and transmitter plugged into the servo board.
I have tried the Movement Panel connecting it to d0 and I can only get the motors to twitch
any ideas?
If you get it working tklass let me know. They just sent me their new 2 x 12 h bridge and I have never used one given this is my first robot.
@jstarne check to see if it has serial mode - if so, you're good to use our control. Otherwise, i cannot give suggestions to use servo mode because I have no experience with it.
I had one Sabertooth controller that i could have tested with - but it stopped working. I'm can't justify spending another $XXX dollars on another.:(
The model they sent can use a few different options , one is rc , these are the others.
This means I can use serial connections on ezb?
I have the same one and followed the directions for both serial modes at 38400 which does not respond with ez b unless you use the servo Tab which works perfectly.
I'm using (2) sabertooths 2 x 12 in my ARMadeus robot. One is set in the RC mode, the other simplified serial mode (9600 baud). Both work fine with the EZ-B.
can you let me know what controls you are using in serial mode and your dip switch config ?
DJ - Is there a better motor controller that you would recommend. I am using the luxmotion kit with 4 motors that should drive like a tank. I don't need mixing for now.
