Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Ez-b Disgard In Coming Buffer
Ez-B Disgard In Coming Buffer
Here's the debug. was working fine until then.
EZB 0:
EZB 1:
EZB 2:
EZB 3:
EZB 4:
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Camera Disabled
Camera Disabled
Error Initializing Camera: System.ArgumentException: Value does not fall within the expected range.
   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   at  .()
   at  .(Control )
   at EZ_B.Camera.StartCamera(String videoCaptureDeviceName, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 160x120
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Speech Recognition Culture: en-US
Loaded speech recognition successfully
Attempting connection on COM15
Connected to COM15 at 9600
EZ-B reports EZ-B Firmware V16
Connected
Comm Err: The operation has timed out.
BbytesToExpect: 1
Received:
Disconnected
Disconnected
Comm Err: Not Connected
BbytesToExpect: 1
Received:
Disconnected
Disconnected
Connected
Disgard incoming buffer (This should never happen)
BbytesToExpect: 1
Received:
Disconnected
Disconnected
BbytesToExpect: 1
Received:
Disconnected
Disconnected
What could be wrong?
#25
@pranav, do you have 0 volts on the I/O?
  1. Can you measure the voltage on the two 2 pins labeled GND and 5V by the status LED?
  2. Do you have a flashing blue status LED when power is applied?
  3. Do you have a flashing red LED on the Bluetooth module?
#26
I have flashing blue status LED and flashing red LED on the bluetooth module... But the voltage across the two pins labeled 5v and GND is 0v, so the I/O pins are reading 0v... The voltage across the OUT and ADJ of LM1084 is 0v...
What shall I do?
Netherlands
Twitter YouTube
#27
@pranav
Your peripheral's regulator is broken, I believe Geoff has already replied to your email with the answer.
#28
So I should replace the regulator... I would like to know about any replacement for LM 1084 as of now it is known that LM 317 cannot be used as it delivers only 1.5A.. So I am looking for any other replacement to LM 1084...
#29
I found that LM338 is rated for 5A ... So can I use it as a replacement... Or if I had to construct an external circuit for it how shall I do it.. Kindly guide me through this...
Netherlands
Twitter YouTube
#30
The LM338 is still an adjustable regulator. The 1084 on the EZ-B is not. This means it can't be used as a drop-in replacement but you'll need to connect it through some wires and use resistors to set the output voltage to 5V.
I'm not an expert at adjustable regulators, I'm sure @Rich will reply to this thread with an answer:)
#31
Unfortunately I'm still learning about regulators so it's all a bit beyond me but if it is adjustable and/or has a different pin out then some external circuit will be the way to go.
The data sheets I've seen for adjustable regulators often have good quality schematics which should explain the circuit that is required. In fact, page 7 of this data sheet has the schematic.
#32
Thank you @Rich , I will construct an external circuit to the regulator... But I would like to know if we can neglect the Iadj term... If so, I can take the resistor values R2 = 3R1 for a 5v output...
