XV Lidar Bridge icon XV Lidar Bridge — Neato XV LIDAR integration for ARC with live radar, 8-zone obstacle detection, NMS support, calibration, and scan watchdog monitoring Try it →
Ez-b Disgard In Coming Buffer
Ez-B Disgard In Coming Buffer
Here's the debug. was working fine until then.
EZB 0:
EZB 1:
EZB 2:
EZB 3:
EZB 4:
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Camera Disabled
Camera Disabled
Error Initializing Camera: System.ArgumentException: Value does not fall within the expected range.
   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
   at  .()
   at  .(Control )
   at EZ_B.Camera.StartCamera(String videoCaptureDeviceName, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 160x120
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Speech Recognition Culture: en-US
Loaded speech recognition successfully
Attempting connection on COM15
Connected to COM15 at 9600
EZ-B reports EZ-B Firmware V16
Connected
Comm Err: The operation has timed out.
BbytesToExpect: 1
Received:
Disconnected
Disconnected
Comm Err: Not Connected
BbytesToExpect: 1
Received:
Disconnected
Disconnected
Connected
Disgard incoming buffer (This should never happen)
BbytesToExpect: 1
Received:
Disconnected
Disconnected
BbytesToExpect: 1
Received:
Disconnected
Disconnected
What could be wrong?
Neil has had that error in the past, I don't remember what the outcome was but I'll see if I can find the topic.
It would seem that DJ has left this issue "hanging in the air" . Per DJ "I'll take a look at the project and see if I can find out what "disgard" meant to me in 2011 "........I dont know if there was a following thread with a resolution. In all due respect he has been/was busy with other major issues...perhaps this might refresh his memory and find time to resolve it.:)
this is what happens: I connect the ez-b to ARC. I tell it to move the head up and down once. the debug flashes with all those things. the blue light on the board went out. finally the head started bobbing up and down.
Hello,
I'm having a similar Issue, but just with the camera not connecting. I've just received the kit, and charged the camera. I can see the wireless pc camera in my device list long with the EZ-B. Below is the error:
Camera Disabled Error Initializing Camera: System.ArgumentException: Value does not fall within the expected range. at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at .() at .(Control ) at EZ_B.Camera.StartCamera(ValuePair videoCaptureDevice, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 320x240
Any suggestions?
Thanks!
What OS are you using Bruceleeroy? And what version of ARC?
Hi,
I'm using ARC Version 2013.07.10.00
Firmware V16
And Windows 7 Home, on my laptop.
