Can multiple cameras work at once independently controlled from different PC?
Louis T
— Edited
Cognitive Sentiment
— Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis.
I don't have that version camera. Does the receiver fob have dip switches to assign different channels?
The ez robot camera uses a secure channel per camera. They will never interfere.
I don't understand the part of the question regarding a different computer.
You can have up to 64 cameras connected to ARC.
DJ...this is for one of my customer, he asked that if it's possible to use multiple EZ Camera at once, each camera on a different PC (for each student) controlling from ARC. Also if using more than 1 camera on a PC, do you need to have a USB receiver for each camera?
You always need a receiver per camera.
Yes, he can use many cameras on different pc's in the same room. The cameras will not interfere with each other. The USB receiver dongle is paired to the camera.
However, be aware that using 2 of the same camera on one PC doesn't work as expected in ARC, only one is selectable (in my experience).
Thank you DJ and everyone for the help.
Yes I've ran several cameras at once , they don't interfere with each others signal. For the money that's a very nice feature verses a analog camera
- Josh S
That's great to know Josh, one less thing to worry about
