Controlling Speed on Dynamixels.
Controlling Speed On Dynamixels.
How would you approach controlling travel speed on a Dynamixel (400 Series) servo when not using Autoposition? I tried setting ServoSpeed prior to calling a servo move command but it doesnt seem to work. Does it need to be done manually in a script using for-to loops and pauses? I could create a loop that takes you from point A to point be in increments rather than a single goto the endpoint command.  That along with a pause between increments should do the job, but since AutoPosition has that built in, I thought maybe there was already a skill available to do it with. I can also try setting parameters onto the servo itself using the Dynamixel wizard, but was hoping to find a way within ARC.
Opencm 9.04 by Robotis
OpenCM 9.04 with Synthiam ARCx drives Dynamixel servos in a web browser for animations, scripts, AI and hardware I/O
USB
Servos 200
ADC ✕
Digital ✕
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Dynamixel by Robotis
Open-source ARC plugin to control Robotis Dynamixel servos (XL-320, AX-12, XL430) via EZ-B, Arduino or Robotis. Supports position, speed, accel.
That is weird. I've never tried adjusting the servo speed on a dynamixel in a script before, but that is definitely the same speed.
#10   — Edited
We did find out the hard way that Robotis, changed the protocols on various servo models...not sure why...my results varied from series to series..I.E. some did not function at all using the dynamixel skill. There is a hack night somewhere as you can see DJ working through and showing they changed the protocols.
What dynamixel model servos are you using for the neck? They may have changed the protocol for the speed on the servos.
I'm using XH430-W350-R but I tried it with some 500 series as well and got the same results. I thought the speed command was just creating a delay loop to slow the servos down,  If they are accessing the dynamixel parameters to do so, I would love to see the skill allow for access to acceleration and velocity settings so that we could dampen the servos start and end points.   I do this all of the time outside of ARC and it makes all of the difference in the world....  All of the vibrations and jerkiness can be tuned out and super smooth results can be easily achieved.
DJ, what servos were you using in order to get the speed command to work? I have almost every type of X series dynamixel here...  I can switch and duplicate your setup
Portugal
#12   — Edited
I dont have those servos but you could try running without the port setting: servo.SetSpeed(port, speed) Or try running this code in ezscript just to debug:
# This will clear the servo speeds for initialization.
ServoSpeed(D1, 0)
# The following will move the servos into desired starting positions.
Servo(D1, 90)
# The following will now set the servo speed for these servos which will be
#used from now on.
ServoSpeed(D1, 10)
Use the latest version of the dynamixel robot skill: https://synthiam.com/Support/Skills/Servo/Dynamixel?id=16142
It has new control commands that allow writing directly to the servo's RAM using the control table. Read the manual section for the robot skill that provides a link to view the control tables for each servo.
If you're able to find a control table address that works for servo speed or acceleration, let me know and I'll update the robot skill accordingly.
I'd like to add a global acceleration parameter to ARC so any servos supporting it would be compatible.
#15
Calling this one resolved by the latest awesome update to the dynamixel library V43!
