Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
South Africa
Continuous Servo Movement Panel
I plugged in 2 continuos rotation servos to my ezb one in D0 the other in D11 and selected continuos rotation Movement Panel while configuring i clicked on the test button and it worked my servo moved front back and stopped properly but when I click save and press any arrow it doesn't work and then after pressing stop my ezb disconnects.
South Africa
Here is a video it of what happens
Mohamed.r
you forgot the link off the video
You really don't need to upload a video. What are you using to power the ezb and servos?... Remember most disconnects are caused by not using the right power source...
South Africa
Let me try to add it again
You can't add a video directly here... You need to upload it to YouTube then link it to here...
South Africa
I'm using recharge batteries and there were fully charged and it working when I'm pressing test but when I click save and try using the arrow then it's stops working
What kind of rechargeable batteries.. ? I don't think "AA"s are good enough... I would be using a 7.4v Lipo instead... Try it with just one servo and see if it works... If it works then it's your batteries not giving enough Juice...
If he's using ez-robots AA battery pack, it seems to supply enough current for 2 continuous rotation servos. If he's using another brand of servo maybe not.
Also, is there any other controls in the project? If so, they could be to blame. Try this with a fresh project with only a continuous rotation movement panel.
