Ultrasonic Collision Script icon Ultrasonic Collision Script Ultrasonic sensor triggers custom script on object detection; configurable interval & min distance, with optional forward-only trigger for navigation. Try it →
Brushless Motor Controller
Dear; Can anyone help me to create a custom Movement Panel to control this brushless motor controller on ARC for EZB Builder? I would greatly appreciate it.
Thanks
  1. Control port GND:Only for control signal VR:Speed regulation,(0-2.5V or 0-5V linear speed regulation).PWM frequency:1K-5KHz. ZF:Forward and backward control(5V high level or 0V low level,if you use 3.3V MCU,you need do adjustment to 5V) M:speed pulse signal output EL:brake function, 0-2.5V or 0-5V linear brake 5V:5V power source for external control device(300mA)
  2. Power port MA ----motor phase A MB ---- motor phase B MC---- motor phase C P- ----DC- P+----DC + 3:Hall sensor port Ha--- Hall a Hb--- Hall b Hc--- Hall c GND---GND 5V---5V input 4:Remarks
Program Arduino Uno with EZB firmware for Synthiam ARC control; pinouts, PWM pins and frequency details for Arduino boards.
USB
Servos 12
UART
ADC 6
Digital 14
Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement.
Can't you just use one of ARC's already offered movement panels? To build a custom movement you will need to know what you want it to do. while you are moving the robot.
Have a read here:  Movement Panels
Does it have to be that brushless motor controller? The documentation is incomplete and it also requires a 5v I/o... you might run into problems finding compatible hardware.
What’s your decision based on to use that controller?
Thanks for responding. Do you have any reference? I am trying to use 2 hoverboard motors for a robot platform.
Look up the projects from Will ---user--fxrtst (Project Gar thread) He had an amazing Hover board hack last year that you could see details how he wired it up working really awesome.:)
Thanks Rob. I will keep on searching will's projects to see if any ideas that I could use.
I took some more looks at the brushless motor controllers. They don’t look complicated even though the documentation is poor.
so even your controller that was posted wouldn’t be difficult to work with. The only question I’d have is the 5v requirement for I/O
Thanks D J. The controller is partially working. When pressed forward both Wheels turned forward. When pressed reverse only one wheel turned reverse, when pressed arrow left the wheels turned opposite to each other. When pressed arrow right only one wheel turned. I think this could be a programming issue.
