Dear; Can anyone help me to create a custom Movement Panel to control this brushless motor controller on ARC for EZB Builder? I would greatly appreciate it.
Thanks
- Control port GND:Only for control signal VR:Speed regulation,(0-2.5V or 0-5V linear speed regulation).PWM frequency:1K-5KHz. ZF:Forward and backward control(5V high level or 0V low level,if you use 3.3V MCU,you need do adjustment to 5V) M:speed pulse signal output EL:brake function, 0-2.5V or 0-5V linear brake 5V:5V power source for external control device(300mA)
- Power port MA ----motor phase A MB ---- motor phase B MC---- motor phase C P- ----DC- P+----DC + 3:Hall sensor port Ha--- Hall a Hb--- Hall b Hc--- Hall c GND---GND 5V---5V input 4:Remarks
@Josephc, Can you post a link to purchase the controller ?
Here is the link. https://www.dhgate.com/product/jyqd-yl02d-agv-balance-car-dual-motor-control/535853239.html
@Josephc There are 4 versions:
which one you have ?Can you post a picture/draw of your setup i.e. wiring ?
Did you use the "swap direction" checkbox? To swap the direction of the motors that turn?
I purchased this one JYQD-YL-02D(99F2)safety start version has LOCK function.(linear speed regulation 0-5V,liner brake:0-5V)
DJ, I swapped for both direction at one time. whenever I pressed the arrow reverse or right only one wheel span.
Okay. Let me take a look and update for you
