Resolved Resolved by ptp!
Arduino Motor Shield With Iotiny
Is it possible to connect a motor shield like an Arduino A000079 Motor Shield to the iotiny to control a pair of DC motors? If so, how would it be wired?
Related Hardware EZ-B IoTiny
Hey, you can upload the Firmware to connect ARC directly to an Arduino...I guess thats the easiest option!:)
#2   — Edited
Hi,  good luck EzAng
@Ezang:
Quote:
I use ARC To drive and control DC motors I with a IoTiny with battery - with a L298N Motor Drive Controller Board Module Dual H Bridge DC Stepper Module for Arduino
Please stop spamming ! Can you please explain how your answer helps answering the user question:
Yes it's possible, but has additional requirements and you will need to use the "Custom Movement Panel"  https://synthiam.com/Docs/Skills/Movement-Panels/Custom-Movement-Panel?id=16077 with some scripting.
A000079 Motor Shield documentation: https://store.arduino.cc/usa/arduino-motor-shield-rev3
You need to connect:
Shield D12 - Iotiny D0  Shield D 3  - Iotiny D1 Shield D13 - Iotiny D2 Shield D11 - Iotiny D3
Plus you will need to connect: Shield GND - Iotiny Black Pin (GND) The shield requires 5V to operate the circuits logic (not the motors), and sources from the Arduino 5V shield.
Out of the box the Iotiny has a stable 3.3v :
looking to the shield schematic: https://www.arduino.cc/en/uploads/Main/arduino_MotorShield_Rev3-schematic.pdf
uses L298N: https://www.sparkfun.com/datasheets/Robotics/L298_H_Bridge.pdf
The L298N accepts 3.3 v, but the shield is built to source 5V from the arduino board.
you have three options:
  1. If you are powering the Iotiny from a stable (not batteries) 5v source you can connect the shield 5v to the iotitny (Vin).
  2. You can try to connect the Iotiny 3.3 v to the Shield 5v and see if it works with a lower voltage.
  3. You need a 5v DC/DC something like this: https://www.pololu.com/product/2851 using a DC/DC you can convert the Iotiny Vin > 6v to stable 5V and feed the shield.
This is only the wiring part, to make it work you will need to use custom Movement panel.
PTP - so does this hbridge work by having the direction true (forward) or (false) reverse? And to stop, simply stop the PWM?
#7   — Edited
Quote:
basically they use a single pin (dir) and nand circuit
both terms are correct:
  1. XNOR for an OR gate that inverts the inputs before OR'ing.
  2. NAND gate: an AND gate with an inverted output.
*** Wrong check the next post ***
The previous post is incorrect, I was in a middle of something, to clarify:
the truth tables:
The truth tables are not the same.
The arduino motor shield uses a XNOR (4077D): https://www.ti.com/lit/ds/symlink/cd4077b.pdf but in the schematic is displayed as NAND (not correct):
the dfrobot uses a NAND gate:
and is correct they use the NAND as NOT gate
When i did the the post i look the nand symbol and following theirr implementation logic (XNOR) i assumed a NAND and XNOR produce the same output.
They used the wrong symbol for the 4077D ic.
