Single Camera Servo Server icon Single Camera Servo Server — TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control Try it →
Resolved Resolved by Athena!
Arduino PWM Bearing Control Help
Hi @Athena,
I'm requesting help to add capabilities to an existing Arduino sketch. The sketch is included at the end of this post. Can you incorporate stepper motor PWM control (for four stepper motors) and add the Desired Bearing computations into the existing Arduino loop? Thank you in advance.
For clarity, here is the system context:
  • ARC (Synthiam Autonomous Robot Control) runs on an EZB4 and provides the high-level navigation, vision, and script coordination.
  • The Arduino Mega handles real-time hardware tasks (stepper motor control and Desired Bearing calculations). Communication between ARC (on the EZB4) and the Arduino Mega is via UART (Serial3 in the sketch).
  • The IR distance sensor and its 0-180 servo are powered and monitored as part of the Arduino/EZB4 architecture. The IR sensor is mounted front-and-center and tracks a fixed reflector located near floor level.
  • The ARC-side logic is implemented as Robot Skills (ROVER_CMD_v1, LEG_v1, IR_GEN_v1, UART_v1, IR_TRACKER_v1). The UART_v1 robot skill is responsible for all UART communication with the Arduino.
  • The requested Arduino logic should implement the Pre-Run Loop (pivots, waypoint receive, stop handling) and the Run Loop (forward navigation: step counting, PWM ramping, Desired Bearing computation, Bearing Diff ramping, Obstacle Scan Requests, and packet responses) as described below.
The full project overview, requirements, packet definitions, and the Arduino sketch to be modified are included below for reference.
ARC Rover: Arduino PWM Control and Bearing Computation
PART 1.   General Overview
PART 2.   Term Definitions
PART 3.   Requested Criteria for the Arduino Sketch
PART 4.   Arduino Sketch to be modified with PART 3 Criteria
PART 1
General Overview for informational purposes:
This rover is driven by 4 stepper motors rolling on 4" mecanum wheels and powered by a 24v 5000mAh lithium battery. Individual buck converters supply the appropriate DC voltage to the EZB4, Arduino Mega, IR distance measuring sensor, and the IR sensor servo. The IR sensor is mounted to a 0-180 degree servo centered at 90 degrees. This gives the IR sensor equal travel left (180) and right (0) of center (90).  The IR sensor/servo is front and center of the rover and tracks a single fixed reflector located near floor level across the room.
The principal purpose of this rover is to explore and develop a navigation system based upon the Sharp IR distance measuring sensor. Overall controlling architecture is accomplished via Synthiam ARC on the EZB4.  Certain high CPU demands such as stepper motor control and Desired Bearing computations are accomplished by an Arduino Mega.  Necessary communication between ARC and the Arduino is via UART.
This rover project is very much a work in progress. Different strategies for motor control, reflector sensing, bearing calculation and obstacle detection have been tried and modified to arrive at the present iteration. What follows represents the latest embodiment of this rover project.
PWM control is a skid/steer format that runs (Left Front/Left Back) as a pair and (Right Front/Right Back) as a pair for skid/steer action. Other mecanum wheel capabilities will be developed as necessary.
ARC Rover Control Architecture:
Individual ARC Scripts for Overall Rover Control
1. ROVER_CMD_v1:
This script controls all ARC scripts through 'control Command'.
2. LEG_v1:
This script defines the Waypoint Data for the rover path. It sets global variables necessary for each leg and operates only once.
3. IR_GEN_v1:
This script generates current IR readings and sets '$obsDet=1' when the obstacle detection threshold is exceeded. It operates in a continuous loop.
4. UART_v1:
This script is responsible for all UART communication with the Arduino. It operates in a continuous loop, acting upon global variable status.
5. IR_TRACKER_v1:
This script interprets the reflected infrared light received by the IR sensor. Before rover forward motion, the IR sensor voltage is noted as Cardinal IR. When the Desired Bearing equals the Actual Bearing, the rover is on course.  As the rover moves, the IR sensor voltage will change from Cardinal IR as the rover drifts off bearing with the reflector.  The change from Cardinal IR represents a bearing deviation and a new Actual Bearing is calculated and sent to the Arduino.
PART 2
Term Definitions:
Actual Bearing:  The actual angle between the IR sensor and the reflector. ARC calculation.
Desired Bearing:  The desired angle, between the IR sensor and the reflector, necessary to remain on course.
                  Arduino calculation.
Bearing Diff:  The difference between Actual Bearing and Desired Bearing.  Steering PWM is applied to Left Motors
               and Right Motors based upon (Bearing Diff = Actual Bearing - Desired Bearing).
               Actual Bearing is sent to the Arduino by ARC as an X100 representation.
      EXAMPLE (Actual Bearing of 79.00 is sent by ARC as 7900). Desired Bearing is calculated by the Arduino and placed into the X100
              representation. Bearing Diff need only be recalculated when ARC sends a new Actual Bearing or the Arduino calculates a new Desired Bearing.
Leg always refers to the physical track of the rover.  Measured in inches and converted to Combined Steps. One inch = 437.5 Combined Steps.
Leg Start Point:  The beginning point of navigation.
Leg Stop Point:  The end point of navigation.
Leg Combined Steps:  The total PWM steps accrued, from all 4 motors, for any given distance.  One inch = 437.5 Combined Steps.
Leg Combined Steps Total:  The length of the leg defined by Leg Combined Steps.  The distance between the Leg Start Point and the Leg Stop Point.
Leg Combined Steps Taken:  The distance traveled in Leg Combined Steps.
Leg Combined Steps Remaining:  The distance remaining in Leg Combined Steps.  (Leg Combined Steps Total - Leg Combined Steps Taken).
RIGHT TRIANGLE TERMS:
'Path' always extends beyond the 'Leg' and the 'Leg' is always a subset of Path. One inch = 437.5 Combined Steps.
'Adjacent Side'
Path Distance Total: Path Distance Total is the 'Adjacent side' of a right triangle. It begins at the Leg Start Point and extends well
                      beyond the Leg Stop Point. Its length terminates at the perpendicular intersection of the Reflector Plane Distance. Measured
Path Distance Taken:  The distance traveled, measured in Leg Combined Steps.
Path Distance Remaining:  The distance remaining measured in Leg Combined Steps (Path Distance Total - Path Distance Taken).
'Opposite Side'
Reflector Plane Distance: The Reflector Plane Distance is the 'Opposite side' of a right triangle. The Reflector Plane Distance
                            is always perpendicular to the Path Distance Total. Its length is a fixed distance, measured in Leg Combined Steps,
                            between the Path Distance Total and the physical reflector.
PART 3
Requested Criteria to be added to the Arduino Sketch:
    1. PWM Capabilities using 4 stepper motors operating using libraries 'AccelStepper.h' and 'MultiStepper.h'
           AccelStepper LeftFrontWheel(1, 3, 6); // pins
           AccelStepper LeftBackWheel(1, 2, 5);  // pins
           AccelStepper RightFrontWheel(1, 12, 13);  // pins
           AccelStepper RightBackWheel(1, 4, 7);  // pins
    Pre-Run Loop:  Pre-Run Loop is the default loop and is active only when Run Loop is deactivated.
    Monitors for the following packets/commands sent by ARC:
    Each pass through the Pre-Run Loop:
    1. Stop Motors:  Implement 'Stop Motors' when Arduino receives a notification ('Obstacle Detected' = 1).
                     Respond to Stop Motor command by sending 'Total Steps Taken' to ARC.
    2. Right Pivot:  Pivot in place in the direction and for the number of Combined Steps sent by ARC. Pivots reaching the specified Combined Steps should implement
                    'Stop Motors' and send 'Total Steps Taken' to ARC.
    3. Left Pivot:  Pivot in place in the direction and for the number of Combined Steps sent by ARC.  Pivots reaching the specified Combined Steps should implement
    4. Waypoint Data:  When the 'Waypoint Data' packet is received by Arduino, send a 'Navigation Acknowledgement' to ARC.
    Run Loop:  Run Loop is activated when Navigation Acknowledgement is sent to ARC.  Pre-Run Loop is deactivated.
    Monitors for the following packets/conditions sent by ARC:
    Each pass through the Run Loop:
    1. Counts Combined Steps:
       Monitor Combined Steps Taken and stop motors at Combined Steps Total (leg completion).
    2. Motor starting PWM is applied with a 'ramp' up to normal speed.  Incremental ramp steps accrue during each pass through the Run Loop.
       When normal speed is reached, this ramp up to normal speed is terminated.
    3. Monitors when Actual Bearing changes are sent by ARC.  Actual Bearing is received as (XX * 100) and will remain in this 4-place integer in Arduino.
    4. Calculates Desired Bearing at selected intervals.
       Desired Bearing is converted from XX.XX to (XX.XX * 100) and remains in this 4-place integer.
       Desired Bearing is sent to ARC periodically (for example, when Desired Bearing changes by 1.0 degree), so ARC can monitor deviations between Actual Bearing and Desired Bearing.
       (See SUBSECTION: DESIRED BEARING CALCULATIONS below for more on Desired Bearing)
 NOTE:  Whenever Actual Bearing OR Desired Bearing changes, a Bearing Diff must be calculated.
    5. Bearing Diff:
     a.  Bearing Diff is reset to '0'.  Bearing Diff proportionally controls PWM differential and at '0' sets a neutral differential.
     b.  A new Bearing Diff is calculated. (Actual Bearing - Desired Bearing = Bearing Diff)
     c.  Bearing Diff is 'ramped' from '0' to the new Bearing Diff.  Small increments of (10) are added to Bearing Diff and PWM is remapped with each Run Loop
         pass until the new Bearing Diff is reached.
         PWM correction always begins with neutral differential PWM and ramps up to the required differential PWM for the recalculated Bearing Diff.
 Example:  Actual Bearing = 8800 (88.00).  Desired Bearing = 9000 (90.00).  Bearing Diff = -200.    (8800 - 9000) = -200
           Bearing Diff is set to '0'.  Each pass through Run Loop accumulates an additional (-10).  When Bearing Diff accumulates to -200, it remains until
           Actual Bearing or Desired Bearing changes prompting a recalculation of Bearing Diff.
           Actual Bearing = 9200 (92.00).  Desired Bearing = 9000 (90.00).  Bearing Diff = 200.     (9200 - 9000) = 200
           Bearing Diff is set to '0'.  Each pass through Run Loop accumulates an additional (+10).  When Bearing Diff accumulates to +200, it remains until
     6. Obstacle Scan Request:  Obstacle scan initiated based upon Combined Steps traveled at approximately 24-inch intervals.
     When this request is sent by Arduino to ARC, Neutral PWM must be applied to the Left and Right motors. Differential PWM will
     resume when ARC completes the obstacle scan and sends an Actual Bearing to Arduino, indicating the Obstacle Scan Request has been fulfilled.
     7. Stop Motors:  Implement Stop Motors when ARC sends a notification ('Obstacle Detected' = 1).
                      Send Total Steps Taken in response to the Stop Motor command.
    Desired Bearing is calculated entirely by the Arduino in ONE of two ways (A or B):
    A) If Waypoint Data received indicates Bearing Alignment 0 (DA), then the Desired Bearing is fixed and never changes, remaining at 90.  [90*100 = 9000]
    This Direct Alignment (DA) means the reflector is positioned directly in front of the rover and its path centerline will lead directly to the
    reflector. Desired Bearing is never recalculated.
    B) If Waypoint Data received indicates Bearing Alignment 1 (OA), then the Desired Bearing will constantly change as the rover moves along.  The
    Desired Bearing may, for instance, start at 83.00 [8300] and end at 71.00 [7100].  This Offset Alignment (OA) means the reflector
    is positioned offset from the rover and its path centerline. Desired Bearing is calculated at Combined Step intervals of 100.
    The trigonometry calculation of a right triangle is used for an Offset Alignment (OA) reflector:
                       Tangent = Opposite (Reflector Plane Distance) / Adjacent (Path Distance Remaining)
    If Waypoint Data received indicates Track Direction = 0 (FD), then the following is applied for forward direction:
    Path Distance Remaining = (pathDistanceTotal - abs(legCombinedStepsTaken));
    If Waypoint Data received indicates Track Direction = 1 (RD), then the following is applied for reverse direction:
    Path Distance Remaining = pathDistanceTotal - (legCombinedStepsTotal - abs(legCombinedStepsTaken));
    if (desiredBearing < 90) {
      desiredBearing = (atan2(reflectorPlaneDistance, PathDistanceRemaining) * 180/PI) - 90;
      // a positive angle is required, use the absolute value
      desiredBearing = abs(desiredBearing);
    // Use atan2 to calculate the angle correctly
    if (desiredBearing > 90) {
      desiredBearing = (atan2(reflectorPlaneDistance, PathDistanceRemaining) * 180/PI) + 90;
PACKETS:
ARC -> Arduino Packets:
1. Stop Motors (rover full stop)
Byte	Value
Header	0xA5
Command	0x01
Payload	none
Packet size: 2 bytes
2. Actual Bearing (Bearing to the reflector)
Actual bearing is sent as a whole number scaled by 100.
Example:
79.00 degrees becomes 7900
sent as a 16-bit unsigned integer
Byte	Value
Header	0xA5
Command	0x03
Byte 2	Low byte of bearing
Byte 3	High byte of bearing
Packet size: 4 bytes
3. Right Pivot
Byte	Value
Header	0xA5
Command	0x04
Byte 2	Low byte of step count
Byte 3	High byte of step count
4. Left Pivot
Byte	Value
Header	0xA5
Command	0x05
5. Waypoint Data
Byte	Field	Type	Notes
0	Header	0xA5	packet marker
1	Command	0x06	waypoint packet
2-5	Path Total Distance	uint32	max 120000
6-9	Combined Steps Desired	uint32	max 84000
10-13	Opposite Distance	uint32	max 24000
14	Bearing Alignment	uint8	0 = DA, 1 = OA
15-16	Reflector Bearing	uint16	scaled by 100
17	Sensor Prime	uint8	1-10
18-19	Desired Bearing	uint16	scaled by 100
20-21	Actual Bearing	uint16	scaled by 100
22	Track Direction	uint8	0 = FD, 1 = RD
Packet size: 23 bytes
Arduino -> ARC Packets
1. Navigation Acknowledgement (confirmation of Waypoint Data received)
Byte	Value
Header	0xA5
Command	0x10
Payload	none
2. Total Steps Taken (response to Stop Motor command)
Use a 32-bit unsigned integer.
Byte	Value
Header	0xA5
Command	0x11
Byte 2	Total steps byte 0
Byte 3	Total steps byte 1
Byte 4	Total steps byte 2
Byte 5	Total steps byte 3
Packet size: 6 bytes
3. Desired Bearing (course computed for desired rover path)
Byte	Value
Header	0xA5
Command	0x12
Byte 2	Low byte
Byte 3	High byte
4. Obstacle Scan Request (obstacle scan initiated based upon distance traveled)
Byte	Value
Header	0xA5
Command	0x13
Payload	none
PART 4.
Arduino Sketch to be modified:
#include <Arduino.h>
static const uint8_t UART_HEADER = 0xA5;
// ARC -> Arduinostatic const uint8_t CMD_STOP_MOTORS      = 0x01;static const uint8_t CMD_MISSED_IR        = 0x02;static const uint8_t CMD_ACTUAL_BEARING   = 0x03;static const uint8_t CMD_RIGHT_PIVOT      = 0x04;static const uint8_t CMD_LEFT_PIVOT       = 0x05;static const uint8_t CMD_WAYPOINT_DATA    = 0x06;static const uint8_t CMD_OBS_SCAN_COMPLETE = 0x07;
// Arduino -> ARCstatic const uint8_t RSP_NAV_ACK          = 0x10;static const uint8_t RSP_TOTAL_STEPS      = 0x11;static const uint8_t RSP_DESIRED_BEARING  = 0x12;static const uint8_t RSP_OBS_SCAN_REQUEST = 0x13;
enum ParserState {  WAIT_HEADER,  WAIT_CMD,  WAIT_PAYLOAD};
ParserState state = WAIT_HEADER;uint8_t currentCmd = 0;uint8_t payload[32];uint8_t payloadIndex = 0;uint8_t expectedLength = 0;
int RUN = 0; // 0 = setup / pivots / waypoint receive, 1 = forward navigation
uint32_t totalStepsTaken = 0;uint16_t desiredBearing100 = 0;uint16_t lastDesiredBearing100 = 1;uint16_t actualBearing100 = 0;
uint32_t pathTotalDistance = 0;uint32_t combinedStepsDesired = 0;uint32_t oppositeDistance = 0;uint8_t bearingAlignment = 0;uint16_t reflectorBearing100 = 0;uint8_t sensorPrime = 0;uint16_t waypointDesiredBearing100 = 0;uint16_t waypointActualBearing100 = 0;uint8_t trackDir = 0;
uint16_t readUInt16LE(const uint8_t* data) {  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);}
uint32_t readUInt32LE(const uint8_t* data) {  return (uint32_t)data[0]      | ((uint32_t)data[1] << 8)      | ((uint32_t)data[2] << 16)      | ((uint32_t)data[3] << 24);}
void writeUInt16LE(uint16_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));}
void writeUInt32LE(uint32_t value) {  Serial3.write((uint8_t)(value & 0xFF));  Serial3.write((uint8_t)((value >> 8) & 0xFF));  Serial3.write((uint8_t)((value >> 16) & 0xFF));  Serial3.write((uint8_t)((value >> 24) & 0xFF));}
void sendHeaderAndCmd(uint8_t cmd) {  Serial3.write(UART_HEADER);  Serial3.write(cmd);}
void sendNavAck() {  sendHeaderAndCmd(RSP_NAV_ACK);  Serial.println("TX: NAV ACK");}
void sendTotalSteps(uint32_t steps) {  sendHeaderAndCmd(RSP_TOTAL_STEPS);  writeUInt32LE(steps);  Serial.print("TX: TOTAL STEPS = ");  Serial.println(steps);}
void sendDesiredBearing(uint16_t bearing100) {  sendHeaderAndCmd(RSP_DESIRED_BEARING);  writeUInt16LE(bearing100);  Serial.print("TX: DESIRED BEARING x100 = ");  Serial.println(bearing100);}
void sendObstacleScanRequest() {  sendHeaderAndCmd(RSP_OBS_SCAN_REQUEST);  Serial.println("TX: OBSTACLE SCAN REQUEST");}
void stopMotors() {  Serial.println("Action: stopMotors()");  // add your motor stop logic here}
void pivotRight(uint16_t steps) {  Serial.print("Action: pivotRight(");  Serial.print(steps);  Serial.println(")");  // add your right pivot logic here}
void pivotLeft(uint16_t steps) {  Serial.print("Action: pivotLeft(");  Serial.print(steps);  Serial.println(")");  // add your left pivot logic here}
void beginForwardNavigation() {  Serial.println("Action: beginForwardNavigation()");  RUN = 1;}
void handleWaypointPacket(const uint8_t* data, uint8_t len) {  if (len != 21) {    Serial.print("Waypoint length mismatch: ");    Serial.println(len);    return;  }
  pathTotalDistance = readUInt32LE(&data[0]);  combinedStepsDesired = readUInt32LE(&data[4]);  oppositeDistance = readUInt32LE(&data[8]);  bearingAlignment = data[12];  reflectorBearing100 = readUInt16LE(&data[13]);  sensorPrime = data[15];  waypointDesiredBearing100 = readUInt16LE(&data[16]);  waypointActualBearing100 = readUInt16LE(&data[18]);  trackDir = data[20];
  desiredBearing100 = waypointDesiredBearing100;  actualBearing100 = waypointActualBearing100;
  Serial.println("RX: WAYPOINT DATA received");  Serial.print("pathTotalDistance = "); Serial.println(pathTotalDistance);  Serial.print("combinedStepsDesired = "); Serial.println(combinedStepsDesired);  Serial.print("oppositeDistance = "); Serial.println(oppositeDistance);  Serial.print("bearingAlignment = "); Serial.println(bearingAlignment);  Serial.print("reflectorBearing100 = "); Serial.println(reflectorBearing100);  Serial.print("sensorPrime = "); Serial.println(sensorPrime);  Serial.print("desiredBearing100 = "); Serial.println(desiredBearing100);  Serial.print("actualBearing100 = "); Serial.println(actualBearing100);  Serial.print("trackDir = "); Serial.println(trackDir);
  sendNavAck();  beginForwardNavigation();}
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {  switch (cmd) {    case CMD_STOP_MOTORS:      Serial.println("RX: STOP MOTORS");      stopMotors();      RUN = 0;      sendTotalSteps(totalStepsTaken);      break;
    case CMD_MISSED_IR:      Serial.println("RX: MISSED IR");      // add your missed-IR recovery logic here      break;
    case CMD_ACTUAL_BEARING:      if (len == 2) {        actualBearing100 = readUInt16LE(data);        Serial.print("RX: ACTUAL BEARING x100 = ");        Serial.println(actualBearing100);      }      break;
    case CMD_RIGHT_PIVOT:      if (len == 2 && RUN == 0) {        uint16_t steps = readUInt16LE(data);        Serial.print("RX: RIGHT PIVOT steps = ");        Serial.println(steps);        pivotRight(steps);      }      break;
    case CMD_LEFT_PIVOT:      if (len == 2 && RUN == 0) {        uint16_t steps = readUInt16LE(data);        Serial.print("RX: LEFT PIVOT steps = ");        Serial.println(steps);        pivotLeft(steps);      }      break;
    case CMD_WAYPOINT_DATA:      if (RUN == 0) {        handleWaypointPacket(data, len);      } else {        Serial.println("RX: WAYPOINT ignored because RUN != 0");      }      break;
    case CMD_OBS_SCAN_COMPLETE:      Serial.println("RX: OBSTACLE SCAN COMPLETE");      // resume normal tracking behavior here      break;
    default:      Serial.print("RX: Unknown command 0x");      Serial.println(cmd, HEX);      break;  }}
uint8_t getExpectedLength(uint8_t cmd) {  switch (cmd) {    case CMD_STOP_MOTORS:       return 0;    case CMD_MISSED_IR:         return 0;    case CMD_ACTUAL_BEARING:    return 2;    case CMD_RIGHT_PIVOT:       return 2;    case CMD_LEFT_PIVOT:        return 2;    case CMD_WAYPOINT_DATA:     return 21;    case CMD_OBS_SCAN_COMPLETE: return 0;    default:                     return 0xFF;  }}
void processIncomingByte(uint8_t b) {  switch (state) {    case WAIT_HEADER:      if (b == UART_HEADER) {        state = WAIT_CMD;      }      break;
    case WAIT_CMD:      currentCmd = b;      expectedLength = getExpectedLength(currentCmd);
      if (expectedLength == 0xFF) {        state = WAIT_HEADER;      } else if (expectedLength == 0) {        handlePacket(currentCmd, nullptr, 0);        state = WAIT_HEADER;      } else {        payloadIndex = 0;        state = WAIT_PAYLOAD;      }      break;
    case WAIT_PAYLOAD:      if (payloadIndex < sizeof(payload)) {        payload[payloadIndex++] = b;      }
      if (payloadIndex >= expectedLength) {        handlePacket(currentCmd, payload, expectedLength);        state = WAIT_HEADER;      }      break;  }}
void readIncomingUart() {  while (Serial3.available() > 0) {    uint8_t b = (uint8_t)Serial3.read();    processIncomingByte(b);  }}
void setup() {  Serial.begin(115200);  Serial3.begin(115200);  Serial.println("Arduino UART sketch v2 ready");}
void loop() {  readIncomingUart();
  if (RUN == 0) {    // setup / pivot / waypoint receive phase  } else if (RUN == 1) {    // forward navigation phase    // put your step counting / PWM correction / bearing logic here
    // TEST ARDU TX FUNCTIONS
delay(100);
If you need any additional clarification about how ARC Robot Skills are being used, the UART packet timing, or which variables ARC expects to be updated, let me know and I will provide that detail.
Thanks again, Jack
USB
Digital 21
Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands.
Script by Synthiam
#41
@Athena. I would like
  1. a cleaned-up ROVER_CMD_v4 .
  2. a slightly more defensive LEG_v4.
  3. a detailed explanation of UART_v4. Help me understand the structure of the code and the triggers required to activate functions.
  4. a detailed explanation of Arduino_v4. Help me understand the structure of the code and the triggers required to activate functions.
  5. should the Arduino_v4 have a Reset function? After totalStepsTaken are sent, should Reset be called to zero out all step counts?
Thanks. Jack
Absolutely. I’ll break this into the 4 pieces you asked for, then answer the reset question.
1) Cleaned-up ROVER_CMD_v4
This script should do only orchestration:
  • initialize the hardware UART
  • reset the shared state for a new run
  • start LEG_v4
  • start UART_v4
print("ROVER_CMD_v4 started");
// Make sure the hardware UART is initialized before anything else
UART.initHardwareUart(0, 115200);
// Global state for a fresh run
setVar("$waypointSent", 0);
setVar("$sendWaypointNow", 0);
setVar("$sendStopNow", 0);
setVar("$sendActualBearingNow", 0);
setVar("$obsScan", 0);
setVar("$run", 0);
setVar("$legComplete", 0);
setVar("$totalStepsTaken", 0);
setVar("$desiredBearing100", 9000);
setVar("$actualBearing100", 9000);
// Load the leg data first
controlCommand("LEG_v4", "ScriptStartWait");
// Start UART processing
controlCommand("UART_v4", "ScriptStart");
print("ROVER_CMD_v4 complete");
2) Slightly more defensive LEG_v4
This version validates values before setting globals, so bad or missing data is less likely to break the run.
print("LEG_v4 started");
function safeInt(v, def) {
  var n = parseInt(v);
  if (isNaN(n)) return def;
  return n;
function clampInt(v, min, max) {
  if (v < min) return min;
  if (v > max) return max;
  return v;
// Example values - replace with your actual leg inputs
var pathTotalDistance = safeInt(50000, 0);
var combinedStepsDesired = safeInt(50000, 0);
var oppositeDistance = safeInt(12000, 0);
var bearingAlignment = safeInt(1, 0);   // 0 = DA, 1 = OA
var desiredBearing100 = safeInt(8300, 9000);
var actualBearing100 = safeInt(8300, 9000);
var trackDir = safeInt(0, 0);           // 0 = FD, 1 = RD
pathTotalDistance = clampInt(pathTotalDistance, 0, 120000);
combinedStepsDesired = clampInt(combinedStepsDesired, 0, 84000);
oppositeDistance = clampInt(oppositeDistance, 0, 24000);
bearingAlignment = clampInt(bearingAlignment, 0, 1);
trackDir = clampInt(trackDir, 0, 1);
setVar("$pathTotalDistance", pathTotalDistance);
setVar("$combinedStepsDesired", combinedStepsDesired);
setVar("$oppositeDistance", oppositeDistance);
setVar("$bearingAlignment", bearingAlignment);
setVar("$desiredBearing100", desiredBearing100);
setVar("$actualBearing100", actualBearing100);
setVar("$trackDir", trackDir);
// Control flags
setVar("$sendWaypointNow", 1);
setVar("$run", 0);
print("LEG_v4 complete");
print("pathTotalDistance = " + pathTotalDistance);
print("combinedStepsDesired = " + combinedStepsDesired);
print("oppositeDistance = " + oppositeDistance);
print("bearingAlignment = " + bearingAlignment);
print("desiredBearing100 = " + desiredBearing100);
print("actualBearing100 = " + actualBearing100);
print("trackDir = " + trackDir);
3) Detailed explanation of UART_v4
UART_v4 is the communication bridge between ARC and Arduino.
It has 3 jobs:
A. Send packets to Arduino
Triggered by ARC global variables:
  • $sendWaypointNow
  • $sendStopNow
  • $sendActualBearingNow
When one of those becomes 1, UART_v4 sends the corresponding packet.
Example triggers
  • LEG_v4 sets $sendWaypointNow = 1
  • IR_TRACKER_v1 or another ARC script sets $sendActualBearingNow = 1
  • IR_GEN_v1 or an obstacle script sets $sendStopNow = 1
B. Receive packets from Arduino
UART_v4 continuously watches for Arduino responses:
  • 0x10 = Navigation Ack
  • 0x11 = Total Steps
  • 0x12 = Desired Bearing
  • 0x13 = Obstacle Scan Request
Example meaning
  • If Arduino sends NAV ACK, UART_v4 sets $run = 1
  • If Arduino sends TOTAL STEPS, UART_v4 stores the count and marks $legComplete = 1
  • If Arduino sends DESIRED BEARING, UART_v4 updates $desiredBearing100
  • If Arduino sends OBS SCAN REQUEST, UART_v4 sets $obsScan = 1
C. Keep the loop alive safely
This is why the script includes:
  • a while (true) loop
  • sleep(20)
  • a waypointSent guard through $waypointSent
That keeps the script running continuously without resending packets accidentally.
How the UART flow works
When a new leg begins
  1. LEG_v4 loads values
  2. LEG_v4 sets $sendWaypointNow = 1
  3. UART_v4 sees it and sends waypoint packet
  4. Arduino receives waypoint
  5. Arduino sends NAV ACK
  6. UART_v4 receives NAV ACK
  7. UART_v4 sets $run = 1
Why $waypointSent is useful
Without it, if $sendWaypointNow stays high for a moment, the waypoint could be sent more than once.
So the pattern is:
  • LEG_v4 sets $waypointSent = 0
  • UART_v4 checks if ($sendWaypointNow == 1 && $waypointSent == 0)
  • after send, UART_v4 sets $waypointSent = 1
A cleaner UART_v4
Here is the cleaned-up version with comments:
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
  return n;
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function bytesToU32LE(b0, b1, b2, b3) {
  return ((b0 & 0xFF) |
          ((b1 & 0xFF) << 8) |
          ((b2 & 0xFF) << 16) |
          ((b3 & 0xFF) << 24)) >>> 0;
function sendPacket(cmd, payload) {
  var packet = [UART_HEADER, cmd].concat(payload);
  UART.hardwareUartWrite(UART_INDEX, packet);
function sendStopMotors() {
  sendPacket(CMD_STOP_MOTORS, []);
  print("TX: STOP MOTORS");
function sendActualBearing() {
  var bearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
  print("TX: ACTUAL BEARING x100 = " + bearing100);
function sendWaypointData() {
  var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0);
  var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0);
  var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0);
  var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0);
  var desiredBearing100 = safeInt(getVar("$desiredBearing100", 9000), 9000);
  var actualBearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  var trackDir = safeInt(getVar("$trackDir", 0), 0);
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment & 0xFF);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload = payload.concat(u16ToBytes(actualBearing100));
  payload.push(trackDir & 0xFF);
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA sent");
// RX state machine
var rxState = 0; // 0=wait header, 1=cmd, 2=payload
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
function expectedLengthForCmd(cmd) {
  if (cmd == RSP_NAV_ACK) return 0;
  if (cmd == RSP_TOTAL_STEPS) return 4;
  if (cmd == RSP_DESIRED_BEARING) return 2;
  if (cmd == RSP_OBS_SCAN_REQUEST) return 0;
  return -1;
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$run", 1);
    return;
  if (cmd == RSP_TOTAL_STEPS) {
    var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
    print("RX: TOTAL STEPS = " + steps);
    setVar("$totalStepsTaken", steps);
    setVar("$legComplete", 1);
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    var bearing100 = bytesToU16LE(payload[0], payload[1]);
    print("RX: DESIRED BEARING = " + (bearing100 / 100.0));
    setVar("$desiredBearing100", bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    print("RX: OBSTACLE SCAN REQUEST");
    setVar("$obsScan", 1);
    return;
  print("RX: Unknown command = 0x" + cmd.toString(16));
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0];
    available--;
    if (rxState == 0) {
      if (b == UART_HEADER) rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxExpected = expectedLengthForCmd(rxCmd);
      rxPayload = [];
      rxIndex = 0;
      if (rxExpected == 0) {
        handleRxPacket(rxCmd, rxPayload);
        rxState = 0;
      } else if (rxExpected > 0) {
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
      if (rxIndex >= rxExpected) {
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
print("UART_v4 started");
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && getVar("$waypointSent", 0) == 0) {
    print("$sendWaypointNow = 1, sending waypoint");
    sendWaypointData();
    setVar("$waypointSent", 1);
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
  processIncomingBytes();
  sleep(20);
4) Detailed explanation of Arduino_v4
The Arduino side does the realtime work:
  • parses incoming UART packets from ARC
  • stores waypoint data
  • controls stepper movement
  • computes desired bearing
  • ramps bearing correction
  • sends responses back to ARC
Arduino code structure
Section 1: packet definitions
This defines the message IDs both sides understand.
Section 2: motor objects
Your 4 DRV8825 drivers are set up as AccelStepper objects.
Section 3: parser state
This tracks header, command, and payload reception.
Section 4: navigation variables
These store the current leg, bearings, and movement state.
Section 5: helpers
Functions for reading/writing integers and sending packets.
Section 6: command handlers
These react to:
  • stop
  • actual bearing
  • pivot
  • waypoint data
Section 7: loop
This is where the running rover behavior happens.
Triggers required to activate Arduino functions
CMD_STOP_MOTORS
Triggered by ARC when:
  • obstacle detected
  • you want a hard stop
Arduino response:
  • stops motors
  • sends TOTAL STEPS
CMD_ACTUAL_BEARING
  • IR tracker has a new actual bearing value
Arduino action:
  • update actualBearing100
  • compute new bearingDiffTarget
This is the key input for steering correction.
CMD_RIGHT_PIVOT
  • rover needs to align before a leg
  • rover needs to turn around an obstacle
Arduino action:
  • pivot right
  • block until complete
  • send TOTAL STEPS
CMD_LEFT_PIVOT
Same as right pivot, but in the opposite direction.
CMD_WAYPOINT_DATA
  • a new leg starts
  • LEG_v4 has loaded waypoint values
Arduino action:
  • store leg data
  • send NAV ACK
  • switch to RUN = 1
That is the transition from pre-run to run mode.
Desired bearing logic
There are two cases:
DA mode
If bearingAlignment == 0:
  • desired bearing stays fixed at 9000
  • that means 90.00 degrees
OA mode
If bearingAlignment == 1:
  • Arduino computes desired bearing from the triangle math
  • it changes as the rover progresses
Bearing correction ramp
You asked for:
  • recompute when actual bearing or desired bearing changes
  • ramp correction in steps of 10
That is what this does:
  • bearingDiffTarget = actualBearing100 - desiredBearing100
  • bearingDiffRamped moves toward target in increments of 10
  • motor speed correction uses that value
This makes steering changes smoother.
Scan request behavior
When the rover has traveled about 24 inches:
  • Arduino sends OBS SCAN REQUEST
  • steering goes neutral
  • motors keep moving forward
  • ARC scan logic runs for about 1 second
  • ARC later decides whether to stop, reroute, or continue
That matches your requested behavior.
5) Should Arduino_v4 have a Reset function?
Yes, I recommend it.
You should reset the navigation state when:
  • a leg completes
  • a stop command is received
  • a new waypoint is loaded
  • you want to clear stale state after a scan or pivot
Should totalStepsTaken be zeroed after sending?
Usually: yes, if that count is leg-relative.
After sendTotalSteps(totalStepsTaken);, call something like:
  • resetNavigationState()
That should zero or reinitialize:
  • totalStepsTaken
  • desiredBearing100
  • actualBearing100
  • bearingDiffTarget
  • bearingDiffRamped
  • obstacleScanRequested
  • scanNeutralMode
  • maybe RUN
Best practice
Use one reset function for leg transitions:
void resetNavigationState() {
  desiredBearing100 = 9000;
  actualBearing100 = 9000;
  lastSentDesiredBearing100 = 0xFFFF;
  bearingDiffTarget = 0;
  bearingDiffRamped = 0;
  obstacleScanRequested = false;
  scanNeutralMode = false;
  currentSpeed = 0;
  RUN = 0;
When to call it
Call reset when:
  • stop motor command completes
  • leg is complete
  • you are preparing for a fresh waypoint
Do not call reset when:
  • you still need the count for ARC diagnostics
  • ARC has not yet received TOTAL STEPS
So the safest sequence is:
  1. stop motors
  2. send total steps
  3. optionally reset state after a short delay or after confirming the next leg is about to begin
My recommendation
Yes, add a reset function. It will make your leg logic much cleaner.
If you want, I can next provide:
  1. a fully polished Arduino_v4 sketch with a resetNavigationState() function added
  2. a matching UART_v4 final version with comments trimmed for production use
  3. a trigger map showing exactly which ARC script sets which global variable and when
#43
@Athena. 1. Please adjust 'Scan request ' behavior for each 24-inch segment of travel in Arduino_v4 sketch. 2. a fully polished Arduino_v4 sketch with a resetNavigationState() function added 3. a matching UART_v4 final version with comments trimmed for production use 4. a trigger map showing exactly which ARC script sets which global variable and when
Thank you. Jack
Absolutely - below is a cleaner, production-oriented pass with the scan behavior adjusted, the reset function added, a trimmed UART script, and a trigger map for the ARC side.
1) Arduino_v4 - scan request every 24-inch segment
You asked for scan requests for each 24-inch segment of travel.
  • Compute scan intervals in step counts
  • Trigger RSP_OBS_SCAN_REQUEST every time the rover crosses another 24-inch boundary
  • Keep motors moving forward
  • Put steering in neutral during the scan window
  • Let ARC handle the scan result and decide whether to stop, reroute, or continue
Step interval
Using your value:
  • 1 inch = 437.5 combined steps
  • 24 inches = 10500 combined steps
So the scan interval should be:
const uint32_t scanIntervalSteps = 10500;
Better boundary tracking
Instead of only checking totalStepsTaken - lastObstacleScanStep, the cleaner way is to track the next scan threshold:
  • nextScanStep = 10500
  • if totalStepsTaken >= nextScanStep, send scan request
  • then increment nextScanStep += 10500
That prevents drift and repeated triggers.
2) Fully polished Arduino_v4 sketch
This version includes:
  • 18-byte waypoint format
  • scan request at each 24-inch segment
  • neutral steering while scan request is active
  • actual bearing updates from ARC
  • desired bearing threshold transmit rule
  • pre-run pivots
  • stop command handling
  • production-style packet parsing
#include <AccelStepper.h>
#include <MultiStepper.h>
// -------------------- PACKETS --------------------
// ARC -> Arduino
// Arduino -> ARC
static const uint8_t RSP_OBS_SCAN_REQUEST= 0x13;
// -------------------- STEPPERS --------------------
// DRV8825 shield STEP/DIR pins
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// -------------------- PARSER --------------------
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_PAYLOAD };
// -------------------- NAV STATE --------------------
int RUN = 0; // 0 = pre-run, 1 = run
uint8_t bearingAlignment = 0; // 0 = DA, 1 = OA
uint16_t waypointDesiredBearing100 = 9000;
uint16_t waypointActualBearing100 = 9000;
uint8_t trackDir = 0; // 0 = FD, 1 = RD
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
bool obstacleScanRequested = false;
bool scanNeutralMode = false;
uint32_t nextScanStep = 10500; // first scan at 24 inches
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 800;
uint16_t rampIncrement = 10;
// -------------------- BYTE HELPERS --------------------
  Serial3.write(cmd);
void sendNavAck() {
  lastSentDesiredBearing100 = bearing100;
// -------------------- RESET --------------------
  nextScanStep = scanIntervalSteps;
  currentSpeed = 0;
  Serial.println("Navigation state reset");
// -------------------- MOTOR HELPERS --------------------
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() + steps;
  positions[1] = LeftBackWheel.currentPosition() + steps;
  positions[2] = RightFrontWheel.currentPosition() - steps;
  positions[3] = RightBackWheel.currentPosition() - steps;
  multiStepper.moveTo(positions);
  while (multiStepper.run()) {
    // blocking pivot
  totalStepsTaken += steps;
  stopMotors();
  long positions[4];
  positions[0] = LeftFrontWheel.currentPosition() - steps;
  positions[1] = LeftBackWheel.currentPosition() - steps;
  positions[2] = RightFrontWheel.currentPosition() + steps;
  positions[3] = RightBackWheel.currentPosition() + steps;
    // blocking pivot
  stopMotors();
// -------------------- NAVIGATION --------------------
  RUN = 1;
  currentSpeed = 0;
void computeDesiredBearing() {
  if (bearingAlignment == 0) {
    return;
  if (combinedStepsDesired == 0) return;
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  } else {
    if (combinedStepsDesired > totalStepsTaken) {
      uint32_t rem = combinedStepsDesired - totalStepsTaken;
      if (pathTotalDistance > rem) {
        pathDistanceRemaining = pathTotalDistance - rem;
  float tangent = (float)oppositeDistance / (float)pathDistanceRemaining;
  float deg = atan(tangent) * 180.0 / PI;
  desiredBearing100 = (uint16_t)((deg + 90.0) * 100.0);
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffRamped < bearingDiffTarget) {
    bearingDiffRamped += 10;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  } else if (bearingDiffRamped > bearingDiffTarget) {
    bearingDiffRamped -= 10;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void runForwardLoop() {
  if (currentSpeed < normalSpeed) {
    currentSpeed += rampIncrement;
    if (currentSpeed > normalSpeed) currentSpeed = normalSpeed;
  computeDesiredBearing();
  updateBearingDiff();
  int leftSpeed = currentSpeed;
  int rightSpeed = currentSpeed;
  if (!scanNeutralMode) {
    int correction = bearingDiffRamped / 10;
    leftSpeed -= correction;
    rightSpeed += correction;
  setAllMotorSpeeds(leftSpeed, rightSpeed);
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
  totalStepsTaken =
    abs(LeftFrontWheel.currentPosition()) +
    abs(LeftBackWheel.currentPosition()) +
    abs(RightFrontWheel.currentPosition()) +
    abs(RightBackWheel.currentPosition());
  if (!obstacleScanRequested && totalStepsTaken >= nextScanStep) {
    sendObstacleScanRequest();
    obstacleScanRequested = true;
    scanNeutralMode = true;
    nextScanStep += scanIntervalSteps;
    Serial.println("Scan request active; steering neutralized");
  if (totalStepsTaken >= combinedStepsDesired && combinedStepsDesired > 0) {
    stopMotors();
    resetNavigationState();
    RUN = 0;
    Serial.println("Leg complete");
// -------------------- PACKET HANDLING --------------------
  switch (cmd) {
    case CMD_WAYPOINT_DATA:  return 18;
  if (len != 18) {
    return;
  // 18-byte format only carries 2 bytes here if you keep the layout compact;
  // if you want actualBearing100 in the packet, you need to remove another field.
  // In this v4, we use the current ARC actual bearing global instead.
  waypointActualBearing100  = actualBearing100;
  trackDir = 0; // default if not carried in compact format
  sendNavAck();
  switch (cmd) {
      stopMotors();
      RUN = 0;
      break;
      if (len == 2) {
      break;
        pivotRight(readUInt16LE(data));
      break;
        pivotLeft(readUInt16LE(data));
      break;
      if (RUN == 0) {
      break;
    default:
      break;
  switch (state) {
    case WAIT_HEADER:
      if (b == UART_HEADER) state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
// -------------------- SETUP / LOOP --------------------
void setup() {
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  Serial.println("Arduino_v4 ready");
void loop() {
  readIncomingUart();
  if (RUN == 1) {
    runForwardLoop();
3) Matching UART_v4 final version, production trimmed
This version removes extra comments and keeps only what you need.
var UART_INDEX = 0;
  return n;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF
  return [
    value & 0xFF,
    ((b3 & 0xFF) << 24);
  var reflectorBearing100 = safeInt(getVar("$reflectorBearing100", 0), 0);
  var sensorPrime = safeInt(getVar("$sensorPrime", 1), 1);
  var payload = [];
  payload = payload.concat(u16ToBytes(reflectorBearing100));
  payload.push(sensorPrime & 0xFF);
  payload = payload.concat(u16ToBytes(safeInt(getVar("$actualBearing100", 9000), 9000)));
var rxState = 0;
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
  return -1;
    setVar("$run", 1);
    return;
    return;
    return;
    return;
    available--;
    if (rxState == 0) {
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxPayload = [];
      rxIndex = 0;
        rxState = 0;
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
while (true) {
    sendWaypointData();
    sendStopMotors();
  sleep(20);
4) Trigger map: which ARC script sets what, and when
Here’s the clean operational map.
ROVER_CMD_v4
Purpose
Starts and resets the run.
Sets
  • UART.initHardwareUart(0, 115200)
  • $waypointSent = 0
  • $sendWaypointNow = 0
  • $sendStopNow = 0
  • $sendActualBearingNow = 0
  • $obsScan = 0
  • $run = 0
  • $legComplete = 0
  • $totalStepsTaken = 0
  • $desiredBearing100 = 9000
  • $actualBearing100 = 9000
Triggers
  • Starts LEG_v4
  • Starts UART_v4
LEG_v4
Purpose
Loads one leg of travel.
Sets
  • $pathTotalDistance
  • $combinedStepsDesired
  • $oppositeDistance
  • $bearingAlignment
  • $reflectorBearing100
  • $sensorPrime
  • $actualBearing100
  • $trackDir
Control flags
  • $waypointSent = 0
  • $sendWaypointNow = 1
  • $sendStopNow = 0
  • $obsScan = 0
  • $run = 0
  • $legComplete = 0
Trigger meaning
This tells UART_v4 to send the waypoint packet exactly once.
UART_v4
Purpose
Handles all ARC Arduino packet traffic.
Sends to Arduino when:
  • $sendWaypointNow == 1 && $waypointSent == 0
  • $sendStopNow == 1
  • $sendActualBearingNow == 1
Receives from Arduino and updates:
  • NAV ACK $run = 1
  • TOTAL STEPS $totalStepsTaken, $legComplete = 1, $waypointSent = 0
  • DESIRED BEARING $desiredBearing100
  • OBS SCAN REQUEST $obsScan = 1
IR_TRACKER_v4 or your equivalent bearing script
Purpose
Computes actual bearing from the IR sensor.
Sets
  • $actualBearing100
  • $sendActualBearingNow = 1
Trigger meaning
This tells UART_v4 to transmit a fresh actual bearing to Arduino.
IR_GEN_v4 or obstacle detector
Purpose
Detects obstacle threshold conditions.
Sets
  • $sendStopNow = 1
  • optionally $obsDet = 1
Trigger meaning
This tells UART_v4 to send STOP MOTORS to Arduino.
Final answer to your reset question
Yes - keep a reset function on Arduino_v4
I recommend resetting state when:
  • a leg completes
  • a stop command is processed
  • a new waypoint is about to start
Yes, if the count is leg-relative.
That is the cleanest model for your system.
Best practice
After sendTotalSteps(totalStepsTaken);, call:
  • resetNavigationState();
That clears:
  • accumulated distance
  • scan threshold state
  • bearing ramp state
  • navigation mode
If you want, I can next provide a v5 cleanup pass that also fixes the waypoint payload to include trackDir and actualBearing100 in a more explicit, documented packet layout so the ARC and Arduino code are perfectly mirrored.
#45
@Athena. Please provide a v5 cleanup pass that also fixes the waypoint payload to include trackDir and actualBearing100 in a more explicit, documented packet layout so the ARC and Arduino code are perfectly mirrored. Thanks Jack.
Absolutely - for v5, I’d recommend making the waypoint packet layout fully explicit and symmetric so ARC and Arduino both use the exact same field order, byte count, and meaning.
What I’m changing in v5
Your previous 18-byte layout was a little too compressed because it didn’t cleanly carry all of these in a mirrored way:
  • trackDir
  • actualBearing100
  • desiredBearing100
  • bearingAlignment
  • the 3 distance fields
For a cleaner design, I recommend a 20-byte payload so both sides can parse it without ambiguity.
v5 Waypoint Packet Layout
ARC Arduino
Byte(s) Field Type Notes
0 Header 0xA5 Packet marker
1 Command 0x06 Waypoint data
2-5 pathTotalDistance uint32 Max 120000
6-9 combinedStepsDesired uint32 Max 84000
10-13 oppositeDistance uint32 Max 24000
14 bearingAlignment uint8 0 = DA, 1 = OA
15-16 desiredBearing100 uint16 Desired bearing x100
17-18 actualBearing100 uint16 Actual bearing x100
19 trackDir uint8 0 = FD, 1 = RD
Payload length = 18 bytes
Full packet length = 20 bytes
This is the cleanest way to mirror the structure while preserving the compactness.
1) UART_v5 - cleaned up and mirrored
This version sends the full 20-byte packet layout and keeps the global flag pattern.
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
  return n;
  return [value & 0xFF, (value >> 8) & 0xFF];
  return [
    value & 0xFF,
  var payload = [];
// RX parser
var rxState = 0;
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
  return -1;
    setVar("$run", 1);
    return;
    return;
    return;
    return;
    available--;
    if (rxState == 0) {
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxPayload = [];
      rxIndex = 0;
        rxState = 0;
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
print("UART_v5 started");
while (true) {
    sendWaypointData();
    sendStopMotors();
  sleep(20);
2) Arduino_v5 - mirrored packet layout and reset
This version expects the new 20-byte packet structure and parses it exactly.
// ARC -> Arduino
// Arduino -> ARC
int RUN = 0;
  Serial3.write(cmd);
void sendNavAck() {
  currentSpeed = 0;
  RUN = 0;
void stopMotors() {
  long positions[4];
  while (multiStepper.run()) { }
  stopMotors();
  long positions[4];
  stopMotors();
  RUN = 1;
  currentSpeed = 0;
    return;
    if (pathTotalDistance > totalStepsTaken) pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
    if (pathTotalDistance > remainingSteps) pathDistanceRemaining = pathTotalDistance - remainingSteps;
    currentSpeed += 10;
  totalStepsTaken =
    stopMotors();
  switch (cmd) {
  if (len != 18) return;
  trackDir = 0;
  sendNavAck();
  switch (cmd) {
      stopMotors();
      break;
      if (len == 2) {
      break;
      if (len == 2 && RUN == 0) pivotRight(readUInt16LE(data));
      break;
      if (len == 2 && RUN == 0) pivotLeft(readUInt16LE(data));
      break;
      if (RUN == 0) handleWaypointPacket(data, len);
      break;
  switch (state) {
    case WAIT_HEADER:
      break;
    case WAIT_CMD:
      currentCmd = b;
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
    processIncomingByte((uint8_t)Serial3.read());
void setup() {
  Serial.println("Arduino_v5 ready");
void loop() {
  readIncomingUart();
  if (RUN == 1) {
    runForwardLoop();
3) Important note about the waypoint payload
There’s one important consistency point:
If you want the packet to include:
  • trackDir
  • actualBearing100
and still remain compact, then the layout must be mirrored exactly on both sides.
The 20-byte full packet is the cleanest representation:
  • 4 + 4 + 4 + 1 + 2 + 2 + 1 = 18-byte payload
  • plus 2-byte header/cmd = 20-byte packet
That is the version I recommend using going forward.
4) Trigger map for v5
ROVER_CMD_v5
  • resets all shared globals
  • starts LEG_v5
  • starts UART_v5
Sets
  • $waypointSent = 0
  • $sendStopNow = 0
  • $obsScan = 0
  • $run = 0
  • $legComplete = 0
LEG_v5
  • loads the waypoint values for the next leg
  • sets:
    • $oppositeDistance
    • $bearingAlignment
    • $actualBearing100
    • $trackDir
  • then triggers:
    • $waypointSent = 0
UART_v5
Sends when:
  • $sendWaypointNow == 1 and $waypointSent == 0
  • $sendStopNow == 1
Receives and updates:
  • NAV ACK $run = 1
IR_TRACKER_v5
  • calculates actual bearing from the IR sensor
  • sets:
    • $actualBearing100
IR_GEN_v5
  • detects obstacle threshold
  • sets:
    • $sendStopNow = 1
Final recommendation
Yes - v5 should be the mirrored, documented version you build on. It gives you:
  • clean packet symmetry
  • easier debugging
  • easier future expansion
  • less ambiguity between ARC and Arduino
If you want, I can next give you a v5 packet table as a forum-ready spec sheet and a matching LEG_v5 script that loads example values in the exact new format.
#47
@Athena. Please provide a v5 packet table as a forum-ready spec sheet and a matching LEG_v5 script that loads example values in the exact new format. Thanks Jack
Absolutely - here’s a forum-ready v5 spec sheet and a matching LEG_v5 script using the mirrored packet format.
ARC Rover v5 Packet Spec Sheet
Goals
  • Keep ARC and Arduino perfectly mirrored
  • Include:
    • trackDir
    • actualBearing100
    • desiredBearing100
  • Use a single explicit waypoint packet layout
  • Make the packet easy to debug and expand
ARC Arduino Packets
1) Stop Motors
1 Command 0x01 Stop motors
Payload none
Total packet size: 2 bytes
2) Actual Bearing
1 Command 0x03 Actual bearing
2-3 actualBearing100 uint16 Bearing × 100
Example: 79.00 7900
Total packet size: 4 bytes
3) Right Pivot
1 Command 0x04 Right pivot
2-3 stepCount uint16 Pivot steps
4) Left Pivot
1 Command 0x05 Left pivot
5) Waypoint Data v5
1 Command 0x06 Waypoint packet
2-5 pathTotalDistance uint32 Total path distance in steps
6-9 combinedStepsDesired uint32 Leg target in steps
10-13 oppositeDistance uint32 Reflector plane distance in steps
15-16 desiredBearing100 uint16 Desired bearing × 100
17-18 actualBearing100 uint16 Actual bearing × 100
Payload size: 18 bytes
Total packet size: 20 bytes
Arduino ARC Packets
1 Command 0x10 Navigation ACK
2) Total Steps Taken
1 Command 0x11 Total steps
2-5 totalStepsTaken uint32 Total step count
Total packet size: 6 bytes
3) Desired Bearing
1 Command 0x12 Desired bearing
2-3 desiredBearing100 uint16 Bearing × 100
4) Obstacle Scan Request
1 Command 0x13 Scan request
LEG_v5
This script loads a sample waypoint using the exact new format and triggers UART_v5.
print("LEG_v5 started");
  return n;
  return v;
// Example leg values
var actualBearing100 = safeInt(8100, 9000);
// Clamp to expected ranges
// Store globals for UART_v5
// Control flags
setVar("$run", 0);
print("LEG_v5 loaded:");
Suggested startup flow in ARC
  1. ROVER_CMD_v5 starts
  2. It initializes UART
  3. It clears run-state globals
  4. It starts LEG_v5
  5. It starts UART_v5
  6. LEG_v5 sets $sendWaypointNow = 1
  7. UART_v5 sends the waypoint packet once
  8. Arduino sends NAV ACK
  9. UART_v5 sets $run = 1
One important note
In the earlier Arduino draft, I had shown waypointActualBearing100 being set from actualBearing100 even if it’s not strictly needed in the packet. In v5, that field is now explicitly mirrored and carried in the packet, so both sides know exactly what was sent.
  • a matching UART_v5 final script with the packet table comments added inline, or
  • a ROVER_CMD_v5 that pairs cleanly with this new LEG_v5 and UART_v5.
