Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
About Embedded Mini-itx Computer Inside Robots
About Embedded Mini-Itx Computer Inside Robots
I was thinking about embedding a computer inside the robot, my concerns are: how do you operate it without a screen? for example if i were putting it inside an R2D2 or WALL-E robot that don't need a screen. Do you all plug in a screen every time you turn it on?
Which mini-itx board/system? i know about the DELL FX160 $40 but then i gotta buy rams, hdd, usb wifi/bluetooth/sound card, which adds up. Looking for the cheapest solution that runs decent and compatible with Windows 7 if possible for speech recognition. Already have a SSD on hand.
Thanks
#26
I am currently using a laptop but would like to use a mini-ITX. However, I want the script to automatically run at boot up; can this be done? I would only want to have a button for stopping and starting the script, very simple user interface, do not want a screen, do not want a keyboard. Has anyone done this?
#27
Hi Randy,
Now just to clarify are you talking about EZ-B running at start-up? This is something I want to do as well. I know a few people have been working on this and the bug has even been put in DJ's ear. I am not sure if he's working on it or not but I think eventually someone will work it out.
I will start a thread specifically for this. Maybe someone has done it already.
Samantha
#28
My app is a simple talking figure that just repeats over and over. I'm not sure I even need a computer at all. Is there a way to maybe capture to memory (record) the serial data for my script and then have a stand alone serial transmitter over bluetooth perform the function of the laptop? sort of like a repeater but using previously recorded serial data as the input...
#29
Probably but this is out of my realm of expertise.
#30
@Louis I was mistaken in my terminology. I was referring to SHDC .. Or what ever that is called - the SD cards used in cameras and such. It's very slow compared to compact flash.
SSD drives are very fast, yes. I was not thinking straight:) I use SSD in all of my computers. Without SSD drives, i would never be able to live with compiling ARC and the EZ-SDK... Which would take 60 seconds on my I7 extreme with a regular hard drive. It takes 30 seconds or more with SSD:P
#31
Yea you would pull your hair out in that extra 30 seconds lol, did you always use a fast machine like.that or did.you let it drive you nuts till you built something better?
#32
@DJ Yes i figured that's what you meant. lol at your 30 extra seconds, but you need all the time you need right:).
