ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Resolved Resolved by Jeremie!
ez-b v4 not connecting to wifi
Ez-B V4 Not Connecting To Wifi
hi guys, i have a little problem with connecting the ez-b to my computer. My ez-b will not connect to my computer's wifi receiver, it is very strange because it will connect to every other computer i try it on, just not mine. I even tried plugging in a usb wifi dongle and it still will not connect to my ez-b through this computer, but it will connect to other computers that I use that dongle with. i tried disabling windows defender and fire wall and i don't have any other spyware programs installed on this pc. I also tried updating my wifi receivers drivers. It is very strange. I would like to use my ez-b in adhoc mode vs client mode. I have also reset the ez-b by holding the button and restarting my computer. My laptop is an hp pavilion x360 and it’s running on windows 8.1. I really appreciate you guys taking the time to help me out.  ?
Hello Herbie53, Can you connect to anything else with that laptop? I looked up the x360 and it is a convertible so it might have and be in an airplane mode.
RichardZ
hi, thanks for the reply, i do not have it in airplane mode and i can connect to other networks. i have never had a problem like this with my computer before
Can you see the EZB network from your x360?
yes i can, when i press connect, it just says "cannot connect to this network"
@Herbie53: I'm confused...
EZB supports two modes:
1) Client Mode EZB connects to 2.4 Ghz wifi network with SSID and a password, EZB connects to a router.
2) Access Point Mode EZB acts as a wireless router with SSID and computers(clients) connect to EZB network.
You wrote this:
Quote:
connecting the ez-b to my computer My ez-b will not connect to my computer's wifi receiver
In both cases EZB does not connect to your PC or wifi receiver.
So If i understood well you don't want to use the "Client Mode" so the only available option is Access Point Mode although there is an adhoc mode and asfaik nowhere is mentioned as supported.
Can you clarify which mode 1 or 2 you are trying to use ?
I am shooting in the dark here. You more then likely tried this. Go to the properties of your wifi adapter and click on the advanced tab and check with wireless mode it is set to. I have mine set to 6. Dual Band 802.11 a/b/g. Also just look at the other settings and see if anything jumps out at you as wrong. You could try comparing them with another PC that connects.
@PTP I believe he is trying to connect to the EZBv4 from his PC not connect PC to Access Point and EBZ to Access Point.
#8   — Edited
@Rz90208: The details are important, the way he wrote it seems EZB is not connecting to the computer when should be the opposite.
Let's assume EZB is configured in Access Point Mode, the first thing unplug any Ethernet connection and keep only the WIFI dongle or if is a laptop keep the built in wifi on then try to connect to the EZB's network.
