Resolved Resolved by Jeremie!
ez-b v4 not connecting to wifi
Ez-B V4 Not Connecting To Wifi
hi guys, i have a little problem with connecting the ez-b to my computer. My ez-b will not connect to my computer's wifi receiver, it is very strange because it will connect to every other computer i try it on, just not mine. I even tried plugging in a usb wifi dongle and it still will not connect to my ez-b through this computer, but it will connect to other computers that I use that dongle with. i tried disabling windows defender and fire wall and i don't have any other spyware programs installed on this pc. I also tried updating my wifi receivers drivers. It is very strange. I would like to use my ez-b in adhoc mode vs client mode. I have also reset the ez-b by holding the button and restarting my computer. My laptop is an hp pavilion x360 and it’s running on windows 8.1. I really appreciate you guys taking the time to help me out.  ?
sorry for the miscomunication. i want to connect my ez-b to my computer dirrectly, without using it in access point mode.
(sorry I forgot to mention, it is a laptop and I don’t have an ethernet cable hooked up to it)
@Herbie53, What type of EZ-Bv4 WiFi board version do you have?
The version with the Bluegiga module or the newer slash 2 (MXchip module)?
I know the Bluegiga module early firmware had issues connecting to HP computers due to incompatibility of the WiFi chips they had in them.
If you have a Bluegiga module version a firmware update should take care of it, but you'll need a PICKIT programmer. Otherwise, I'd suggest updating to the slash 2 WiFi board.
oh okay i do have the older board, so that must be te problem.
oh okay, I do have the older board, so that must be the problem. Thanks for your help guys, now I know that it’s just my computer that is in compatible. Just one unrelated question though. Have any of you guys tried using an Arduino with the ez-b software. I would prefer a wired connection for my next project so I was thinking with going with the Arduino rout. I just wanted to know if you could give a speech recognition command to ARC and then the software would tell the Arduino to output 5 v signal, has anyone ever tried this. Thanks again for all of the help.
#14   — Edited
So you are trying ad-hoc mode i.e. Windows creating wifi network and EZB in client mode connecting to windows network ?
If that is the case EZB does not support that mode. In adhoc mode Windows creates the network but does not provide a DHCP server, so EZB eventually connects to network but can't get an IP from windows, for that to work you will need to assign a static IP in EZB, and that option does not exist so is not supported.
Check this url: https://superuser.com/questions/1087615/windows-10-adhoc-connection-and-dhcp-control
btw i have an adhoc network:
Is a windows 7 sharing the network, I use to quarantine bad applications, I can connect but nothing gets out from there, and is called Phoenix, because frequently the environment is regenerated.
#15
no, i was not trying to connect through client mode, i was trying to connect through access point mode, but it's ok, i realized that i just have an older version of the ez-b and it will not connect to HP laptops.
If you replace your EZB top with the newer slash 2 (MXchip module). You will be able to connect EZB with a USB serial cable.
