Benchmark icon Benchmark — Diagnose EZ-B connection speed and reliability; benchmark ADC read rates (4-70/sec), reveal flood-control effects and optimize data throttle. Try it →
Vietnam
Resolved Resolved by ptp!
error plugin in visual studio
Error Plugin In Visual Studio
hello, i am not familiar with plugin creation and am having trouble with errors in visual studio, i hope someone can help me? Sincerely thank you! M-TP !
  M-TP
Synbot Plugin by Jlucben
Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support.
Vietnam
#2   — Edited
Sorry, but I am not familiar with .net, the error is quite obvious but I only fix each statement if it is fixed and will need a long command and it switches to another error:"Severity Code Description Project File Line Suppression StateError CS1061 'Form1.SpeechErrorEventArgs' does not contain a definition for 'SpeechErrorCode' and no accessible extension method 'SpeechErrorCode' accepting a first argument of type 'Form1.SpeechErrorEventArgs' could be found (are you missing a using directive or an assembly reference?) EZFormApplication C:\Users\HP\source\repos\ClassLibrary7\EZFormApplication\Form2.cs 1041 Active"   I think there will be something to do, sorry you can help me. Best regards! M-TP
Vietnam
This is my code: private async void OnIntentHandler(object sender, string SpeechIntentEventArgs ) {
        WriteDebug("--- Intent received by OnIntentHandler() ---");
        WriteDebug(e.Payload);
        dynamic intenIdentificationResult = JObject.Parse(e.Payload);
        var res = intenIdentificationResult["topScoringIntent"];
        var intent = Convert.ToString(res["intent"]);
        switch (intent)
            case "TrackFace":
                    ToggleFaceRecognitionEvent?.Invoke(this, null);
                    break;
            case "ComputerVision":
                    var currentBitmap = camera.GetCurrentBitmap;
                    var cvc = new ComputerVisionCommunicator();
                    var description = await cvc.RecognizeObjectsInImage(currentBitmap);          (1)
                    ezb.SoundV4.PlayData(ezb.SpeechSynth.SayToStream(description));
                    break;
            case "FindScrewdriver":
                    //We are trying to find screwdriver, first in front, then on the right, last on the left
                    ezb.SoundV4.PlayData(ezb.SpeechSynth.SayToStream("I am on it"));
                    this.ezb.Servo.SetServoPosition(HeadServoHorizontalPort, mapPortToServoLimits[HeadServoHorizontalPort].CenterPosition);       (2)
                    this.ezb.Servo.SetServoPosition(HeadServoVerticalPort, mapPortToServoLimits[HeadServoVerticalPort].MinPosition + 55);            (3)
                    await Task.Delay(1000);
                    if (RecognizeObject("screwdriver"))
                        //Forward();
                        //squatGrabPosition.StartAction_Grab();
                        //Reverse();
                        ////Grab
                        ezb.SoundV4.PlayData(ezb.SpeechSynth.SayToStream("Screwdriver is in front of me"));
                        return;
error:     (1)Severity Code Description Project File Line Suppression State Error CS0246 The type or namespace name 'ComputerVisionCommunicator' could not be found (are you missing a using directive or an assembly reference?) EZFormApplication C:\Users\HP\source\repos\ClassLibrary7\EZFormApplication\Form2.cs 796 Active  (2)Severity Code Description Project File Line Suppression State Error CS0103 The name 'HeadServoHorizontalPort' does not exist in the current context EZFormApplication C:\Users\HP\source\repos\ClassLibrary7\EZFormApplication\Form2.cs 194 Active (3)Severity Code Description Project File Line Suppression State Error CS0103 The name 'mapPortToServoLimits' does not exist in the current context EZFormApplication C:\Users\HP\source\repos\ClassLibrary7\EZFormApplication\Form2.cs 806 Active
Vietnam
yes i found the answer thank you
