TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Wiring In A Converter
Ok so in preparation for my V4 coming i'm buying last minute things. one thing that's needed is a way to convert the voltage from the board to 5 volts for sensors. This is what a came up with. Yes or no?
If I missed something let me know.
#17
@Herrball...Power.... hard to find a battery or power supply to provide a steady 5v to the ezb (to make your sensors happy) and yet will also output some serious amps... Second, most servos need more than 5v to work to their potential.... And even if you use 7.4v lipo, you will now need a way to reduce the voltage from the digital pins that you are running sensors (to 5v)... I like using 12v sla batteries because they are cheap and provide tons of power (amps)...
#18
Sorry guys, I don't mean to be a butt here ... lol ... but that diagram to me, makes no sense at all. We have to remember that it is talking about a v4. Why would you want 12volts going into the board? If you do that then every output pin will be putting out 12 volts. Way to much for servos and sensors. Wouldn't it make sense to put the 12volt battery into a high amp adjustable drop down board and then into the v4. You would then be able to place the input voltage at any thing you want, or needed.
@RichardR I like using the sla batteries too. You just can't beat then for power and amperage. I have three of them in my big bot. Two for the 24volt motors and one to run the mini motherboard and EZB stuff.
#19
Here's something I've found out about feeding between 5vdc and 7vdc into the V4 EZB; If you supply voltage within this range it will shut down the digatal I/O pins and start nagging you in a femail voice that her batteries are low. You can override this in the connections control settings tab of ARC so it will not do this when connected to ARC or after you disconnect. However every time you power up, this irritating event will happen till V4 is able to connect to ARC again. It would be nice to be able to turn this off from it's web server page so the battery tender is disabled from power up. However you can only do it from ARC and the setting must reside in temp memoy till powerdown.
#20
Herr Ball, yes you could do exactly what you said, ie drop down board. There are more than one way to skin this cat. I read somewhere that most sensors are 3.3 volt tolerant which is what is supposed to come out the analog in ports (I believe). You are correct that 12 volts is too much for most servos. I think the steady supply voltage to the ezb board is what some are shooting for here. As I now see Dave has posted above this and his post seems to follow this theory
#21
thank you for bringing that up that point Herr! I just realized that I forgot about the servos! ok so I think ill use my setup with a 5amp regulator set to 7volts and then put lm1084s in the sensor lines to regulate lower. Thanks everyone!
#22
Does anyone know a 5amp 7v regulator? I've been looking and cant find one. I want it to be under $10 if possible.
#23
I would guess you'll need an adjustable regulator to output 7v. And requiring 5A may be an issue.
That said, are you sure 5A will be enough? How many servos etc. will run from it? It only took 2 TowerPro MG995s to brownout my V3.
