Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Wii Remote Bluetooth Discovery Question  Windows 7
I was going to assign a Wii Remote project for my students to work on, but wanted to try it out before assigning. I am using Windows 7 Enterprise Ed on a PC with a USB Bluetooth device. The Bluetooth device is manufactured by Cambridge Silicon Radio Ltd. and does load its drivers properly into Win 7 (at least it looks like they're properly working according to the Bluetooth Settings Hardware tab). The window shows both a Generic Bluetooth Radio and a Microsoft Bluetooth Enumerator working properly.
My problem occurs when I try to get Windows to discover the Wii Remote Bluetooth device. Prior to performing the discovery, I disconnect from my school's network by disabling the LAN port on the PC and disconnecting the WiFi connection. I then try to Add a Device which pops up a new window that displays any Bluetooth or WiFi available devices. I either press the 1 & 2 buttons simultaneously or press the red button inside the battery compartment to place the Wii Remote into discovery mode. In either case no new devices appear on the Add a Device window. I try this scenario over an over either by pushing the 1 & 2 buttons down well after the blue flashing stops on the Wii, or by pushing the red button in the battery compartment. Nothing seems to work. I'm at a loss on what to do next.
If anyone has suggestions on what I can try next, I would be very grateful.
am not sure but doesn the original wiimote color is white ?
The wiimote I'm using is white, but more than likely it is not an original from Nintendo.
My wiimote does not have the "Wii" imprinted on it so it must not be a Nintendo.
indeed, i got two bad ones too.
