robo rad
— Edited
Wheeler Chair Robot
I saw that last year somebody had built a wheel chair robot?. My idea for the new Robot will be as a stage mascot that can also pretend to play the drums on stage. My brother has a live Metal band every Saturday night and most of the time we have trouble with no drummer showing up. We end up using a Drum machine instead with the 2 other guys on real guitars and singing. So Terminator will be able to move around and substitute behind the drum kit with the Live drum machine signal activating terminator arms at the drums. Also need him to move around in a wheel chair , so is anyone out there that has done this wheel chair hack, looking for suggestions on power/motor controller connections etc...should not be too hard just larger than I'm used to building. This is a youtuber that bought what I just bought,takes a month to get from China and we are building the rest of the Endoskeleton to integrate in wheel chair....
EZ-B V4
by EZ-Robot
Servos
24
UART
3
ADC
8
Digital
24
HAhaha attack!
Have you tried using the Audio.SetVolume() command? Or there is one in ezscript as well. You can set it for a value over 100 and that starts overdrive, which gives a bunch of distortion.
Here's the javascript manual for set volume: https://synthiam.com/Support/javascript-api/Audio/setVolume You'd have to check EZ-Script manual if you're using ez-script, but it's similar.
So in javascript you could go...
Actually no never really tried set volume as I usually have a loud speaker on robots but that could come in handy to make more Quiet when needed!
Wow, just saw an ad
Wow, just saw an ad for both revolution 6 and JD robots. 6 has 12 hdd servos and JD has 6 but JD is 200 dollars more than 6,? At robotshop Canada.Weird unless 6 still only comes with regular HD servos.oh but JD Does have the funky RGB lit eyes.
JD has 16 servos, not 6... plus it has an rgb display
Okay thanks for clarification ,I guess I needed glasses to count all the servosxD
I am running into a problem with my left side Ultrasonic sonar, the one on the right works perfect but that lefty picking up false pings all over the place! These are older cheap sensors used on several past robots, may upgrade to Sharp Infrared collision sensors instead,keep the 1 good sonar for the back side.
I removed the Auto Position Movement Panel that was modified to run all the Cylon servos. Only the Roomba Movement Panel still there. Now with forward movement, both Sonar sensors are clean with no False blips in the way. Could be a ground wire issue as I have had that happen before on previous bots.Will do some testing in the main living room today, fingers crossed!
