How did DJ connect wall-e's led for his eye to the ez-b?
— Edited
Wowwee MIP V2
— UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200
sure i guess. i think that will help future roboteers like me with this topic.
I still learn something new every day, I didn't realise that you can power an LED from the signal wire.
So yes, DJ has a much simpler solution. Snip off a servo extension, wire the LED directly to the black and the white wires just like in DJ's pictures.
yep thanks for the help both of you.
these are the extension cables i bought for the camera and arm servos of my wall-e. these are the right ones right? www.ebay.ca/itm/20X-300mm-Servo-Extension-Lead-Wire-Cable-For-Futaba-JR-/270814992800?pt=US_Character_Radio_Control_Toys&hash=item3f0dd4d9a0
Yep, they will do.
k i was getting skeptical about thoughs wondering if they were right or not.
Thanks. when i start my project in the project showcase in march ill give you and Dj a shout out.
On the I2C BlinkM, you seem a little confused on how to wire it up. It connects to the I2C port not to the Digital ports. So it has 4 wires from the I2C header on the EZB to the 4 connections on the BlinkM. Just marry up the connections on both... that's if you go down that route.
