Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
Netherlands
#17
Hi there,
Try the next few things :
first open a project. make sure you have added the ezb.dll add the reverence -> ezb.dll for x64 you have to change the Active solution platform to X86 -> configuration manager in debug make sure u have disabled the loaderlock -> debug, exeptions -> managed debug assist.
That did it for me.
#18
confused All Hi, Issues with running the C# example code, to specific the "servo-Test" program.
  1. See attached file.
Thanks
Netherlands
#19
what is the problem and where is the attachment ?
#20
Please follow the instructions in the included readme.txt file in the sdk package.:)
#21
I did to the letter before i wrote to you about the issue. Maybe you should read what i wrote?? anyway after repeating the entire procedure there was no change in the outcome. I will continue to debug the issue. thanks for your help. George
#22
@garober, all you wrote was this:
Thanks
If you can provide me more information, i'm certain i'll be able to help. My suggestion is to follow the README.TXT file. That will provide you with the necessary configuration steps to compile. From that point, anything in the SDK ZIP will compile:)
#23
hi I am trying to learn C# and I got to run the tutorial or atleast no erros show but I can not see the code. Now in form I get to connect the EZ-B but still the buttons to do forward or reverse dont work and I can not see what ports I need to connect the servo.
Please could any one guie my to the next step.
coljc85
Hi Coljc85, I think this is what you are asking for, click this button and you should see the forms code:
My advice if you want to learn C# is to check out the online tutorial sections that you access from the visual studio IDE or just google it and microsoft has a ton of good beginner stuff.
