Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
" Mixed mode assembly is built against version 'v1.1.4322' of the runtime and cannot be loaded in the 4.0 runtime without additional configuration information. "
on the line
"this.ezB_Connect1 = new EZ_B.EZB_Connect();"
Interesting! I will give it a shot and take a look. I am in San Fran at Make Faire, so my time is limited. I'll post something soon as i have a minute to check for you:)
I won't have the time for a few more days to look. Can you change the .Net version for the project in VS Express? If so, select 3.5 instead and see if that helps.
Maybe I'll make a 3.5 and 4.0 DLL someday soon:)
The i getting build errors confused
Can you post your code? It looks like the dll is not added as a reference to the project.
What code is it you want to see? The only thing I have added to the form is the EZB_Connect
Ah okay. Try right clicking on the project folder (in the visual studio explorer window) and select "Add References". Use Browse and select the EZB.DLL file.
Did a fresh install of Visual C# express 2010 but still the same error confused Yes, I have added the EZB.DLL file And the only thing I have added in the windows form is the ezb_connect tool.
  • Egil
