Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
Using Substring With An Array
Again I cannot see what I am doing wrong. Is this another bug or am I using the array incorrectly? This works
DefineArray($TestArray,2)
$SearchString = "aaaa"
$TestArray[1] = "<aaaa><bbbb><cccc>"
if($SearchString = SubString($TestArray[1],1,4))
Print("Correct")
endif
This Dont
if($SearchString = SubString($TestArray[1],1,IndexOf($TestArray[1],"><")))
You have one too many closing brackets in this line...
if($SearchString = SubString($TestArray[1],1,4)))
Edit never mind you fixed it...
@RichardR I tried to simplify the expression, and didn't remove the extra closing bracket. But when I did simplify it, it did work.
Still have the issue with the IndexOf with in the expression
If I use a variable in the expression it works.
$TestIndex = IndexOf( $TestArray[1],1,"><" ) -1
if($SearchString = SubString($TestArray[1],1,$TestIndex))
Print("Correct")
endif
@rz90208
EZ-Script is good for simple scripts, and i believe it was developed for simple statements.
there are no expression trees or byte code translation the script lines/statements are evaluated on the fly using a text parser and the things can get complicated with nested conditions, multiples arguments, operators etc.
with that in mind you have some options:
  1. Simplify the expressions like using variables, remember everything is evaluated on the fly so replace multiple function calls assigning the function result to a variable and reusing the variable to check the result.
  2. Avoid nested expressions
  3. Avoid complex scripts when possible
OR
  1. Learn c# and create a plugin
  2. use the DJ's Javascript plugin:
https://synthiam.com/redirect/legacy?table=plugin&id=224
the plugin uses a Javascript Interpreter for .NET (Jint) https://github.com/sebastienros/jint
Is not fast as c# code but it's well known, and if you find a language/parser issue you can open a ticket.
Thanks ptp, I did just that and simplified the script using variables. It is not easy to build even a simple brain and not write complex scripts. I do know some JavaScript, would be nice to have a script manager for js as we do for ez-script. Thanks again for your reply.
This code works perfect
definearray($testarray, 2)
$searchstring = "aaaa"
$testarray[1] = "<aaaa><bbbb><cccc>"
IF ($searchString = substring($testarray[1], 1, 4))
  print("correct")
ENDIF
And so does this, by adding spaces (for some reason) with proper code formatting
if($SearchString = SubString($TestArray[1], 1, IndexOf($TestArray[1], "><")))
Print("Correct")
endif
If you wish to use javascript, use the javascript plugin from here: https://synthiam.com/redirect/legacy?table=plugin&id=224
@DJ,
To help troubleshoot:
DefineArray($ArrayOfStrings,2)
$ArrayOfStrings[0] = "foo;bar;baz"
$SearchString = "foo"
#this works
$index1=IndexOf($ArrayOfStrings[0],";" )
if($SearchString=SubString($ArrayOfStrings[0],0,$index1,";" ))
  print("1: starts with foo" )
endif
#this works too
$String1=$ArrayOfStrings[0]
if($SearchString=SubString($String1,0,IndexOf($String1,";" )))
  print("2: starts with foo" )
endif
#The code below works with a space before the IndexOf
if($SearchString=SubString($ArrayOfStrings[0],0, IndexOf($ArrayOfStrings[0],";" ) ))
  print("3: starts with foo" )
endif
#The code below does not work
#Error on line 24: Variable is an array: $ArrayOfStrings
if($SearchString=SubString($ArrayOfStrings[0],0,IndexOf($ArrayOfStrings[0],";" )))
  print("4: starts with foo" )
endif
EDIT: I've changed the code with several combinations, a space before the IndexOf does the trick
