Intel Realsense T265 icon Intel Realsense T265 — T265 VSLAM for ARC: SLAM-based mapping and precise way-point navigation, low-power tracking, and NMS telemetry. Try it →
Turn AdventureBot using angles
Turn Adventurebot Using Angles
I am pretty new to working on the AdventureBot, and a class project requires me to make it turn at certain angles, such as turn left 55 degrees, turn right 34 degrees, etc. I have tried varying the speed of the left and right HDD motors, but to find an angle I have to do several tries to find the perfect setting, and repeat it for new values of angles. Also, the speed settings change with the surface of the floor. I do not seem to find a pattern in the left and right speed values either, through which I can write generic code for converting motor speeds to exact angles either for a particular surface.
Has anyone faced a similar problem? If yes, then how can I implement such an operation on AdventureBot? Is there a library or app that I can install on ARC?
Thanks
Adventurebot by EZ-Robot
AdventureBot with Synthiam ARCx: drive, stream live video, follow faces and colors, use speech, AI, and browser control.
Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent.
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
lol, that is what I said above, be well
