Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Software Compatibility With Logitech Extreme 3D Pro Joystick
Hi,
Was planning on controlling the robot using ARC software via Logitech Extreme 3D pro. Its simply a USB joystick that allows binding of keys. Again, looking to find out if this is compatible with ARC software. Further specs are listed here: https://www.futureshop.ca/en-CA/product/logitech-logitech-extreme-3d-pro-joystick-963290-0403/10034092.aspx?path=93d81a001f82500107d5c7540940b6a5en02
Thanks,
  • Ankit
If the joystick basically simulates key presses then yes it will work with the keyboard control.
That joystick also works as a joystick - by default. I don't know anything about simulating key presses. But I do know it's a regular joystick and it will work with Joystick Control
@ Ankit , hello could you close this thread by choosing someone who answered it? Thanks in advance ! - Josh
