Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
The EZ-B will move the servo from the 0 position to the 180 position, these are not necessarily degrees as it can vary between servos. If your servo is not moving to the desired position when you set it to either 0 or 180 (0 or 100 in old versions) then the problem lies with the servo not the software or the EZ-B.
Ok but it doesn't seem I am getting full movement.. only to 90 degrees.
Is the control in ARC set up correctly to allow full movement?
If ARC's servo control is set to 0 then the servo will be at the lowest position, if set to 180 it will be set to the servos highest position.
The servo control has a value from 1 -100. I do not see 180.
Hi @jackphillips what version of the software are you using? Have you upgraded lately?
Current version updated this week.
In any servo Config Menu...
  • Set the Min value of the servo to 1
  • Set the Max value of the servo to 100
Now when you use that servo, you can move the servo position between 1 and 100. If the servo does not move the full range, it is because the servo pulse is too small for that unusual servo type. As the instructions in their manual says, you may need a servo stretcher:)
Leave it to HiTech to change the way servos work:P
Hi DJ, Look like it needs more than that and servo needs pulled apart and adapted... I will try one and let you know. They have a way on there web site disassemble and change the config on that relay... If I mess up $40 down the drain.
