Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
Servo Causes Program To Freeze
I am doing speech and "robot move forward" and the servo runs but then I can't shut it using the servo control and the ez program keeps freezing on me. When this happens I get the message "I have successfully connected to your network" and why this is resetting, I have no clue. Anyone have any ideas? Also the program keeps telling me to update the ez program but I did and it still flashes for the upgrade even it acknowledged the upgrade a few days ago.
fc
Sounds like you are not providing enough current for the servo. What are you using for the power source?
@frankcottnj As DJ mentioned it's probably a power problem... or more specifically lack of it. You should be using either Lipo batteries, SLA Lead acid or a Sub C nimh battery pack....
Hi Dj, it is 7 volt 1 amp power supply I had to use because the barrel plug doesn't fit into the receiver. I also tried to just run a simple server script. What size barrel do we use on these so I can order one online?
Thanks so much frank
@frankcottnj 1 amp is not nearly enough power for even 1 servo.... For comparison a 20amp power supply might be enough to run Revolution Six... I use a 60amp power supply to run my inMoov... It works well as long as I use Jeremie's super cap mod....
Barrel Plug Barrel plug with deans battery lead
