Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Scripts will not run from previous synthiam version software
Scripts Will Not Run From Previous Synthiam Version Software
I have tried to run both ARC 4.3 and ARC 4.5 with scripts from my previous Synthiam software.    I receive an error code that identifys a LOOP LABEL as not identified.  I have reidentified the LOOP and still indicates an error. I have performed multiple EZB4 resets and removed/reinstalled above software versions to include a computer retart. I am using widows 10 All scripts operated beautifully until I updated this morning.  I tried ARC 2 and problem remains. Any help? I'm desparate. Jack
#17   — Edited
Here's an example of using public (global) and private variables in a loop...
Notes:
  • notice how a public (Global) variable has a $ (dollar sign) at the beginning. A global public variable means it can be accessed by all scripts.
  • the variable "countThisIsNotPublic" does not start with a $ (dollar sign). Therefore, it only exists within this script. It cannot be accessible by other scripts.
  • see how the main code is within a "loop forever". That will loop for ever, as the name suggests. You can exit the loop with a BREAK. Or you can exit the entire script with a HALT or a RETURN
And here's the JavaScript it generates...
countThisIsNotPublic = 0;
while (true) {
  setVar("$MyGlobalVariable", Utility.getRandom(0, 10));if (getVar("$MyGlobalVariable") == 5) {
    print("The random number matched my number");
    break;
  countThisIsNotPublic = (countThisIsNotPublic + 1);
print("Break got me here because it breaked out of the loop.");
print("It took " + countThisIsNotPublic + " times to guess my number with random");
#18
Thanks a million, I think I'm back on track. Jack
