EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Scripts will not run from previous synthiam version software
Scripts Will Not Run From Previous Synthiam Version Software
I have tried to run both ARC 4.3 and ARC 4.5 with scripts from my previous Synthiam software.    I receive an error code that identifys a LOOP LABEL as not identified.  I have reidentified the LOOP and still indicates an error. I have performed multiple EZB4 resets and removed/reinstalled above software versions to include a computer retart. I am using widows 10 All scripts operated beautifully until I updated this morning.  I tried ARC 2 and problem remains. Any help? I'm desparate. Jack
I have tried ARC 4.6.  I have been able to run my one script using ADC7.  Thankyou. However, the rest of my scripts have multiple GOTO in Blockly.  These do not lend themselves to FOREVER Looping.  These scripts all error with Label not defined.
Does latest ARC support Blockly?
I'm really stuck here.  My project of 3yrs is now bricked because this latest version will not run my scripting.  All 11 scripts were functioning beautifully together this morning before the update.
Is it possible to obtain a previous version so that I may continue my work until your Blockly issues get sorted out? Thankyou very much, Jack
Replace the GOTO with LOOP FOREVER. GOTO is not a supported in JavaScript:). I provided examples earlier in this thread for ya
Ok  Thanks.  I'll set to reworking my Blockly scripts by removing my GOTO commands. Jack
Hi DJ One more question.  You provided an example of using a Variable globally across the entire project.  This was done in JavaScript. Can you provide an example in Blockly?  I did this often in Blockly with the past ARC revision but cannot seem to get it to work now. Thank you Jack
#15   — Edited
OK thank you DJ.  I was able now to control variables globally.   I downloaded the latest beta. I have reviewed the link that you provided previously:
Quote:
A label: is defined in JavaScript quite differently, see here: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/label
And more specifically, someone attempting to use it in the similar fashion and realizing the label: needs to be applied directly before a looping statement, here: https://stackoverflow.com/questions/6393648/why-is-this-labeled-javascript-continue-not-working
However I cannot make sense in blockly.  Nothing works for me.  Could I impose for a simple example in Blockly of LABEL, CONTINUE, & BLOCK. Thanks so much. Jack
#16   — Edited
Stop using the label and continue and use loops instead. Do not use the label because it doesn't seem to apply to your needs.
All you seem to need is are loops. You want code to loop. So use the loop instead of thinking about labels. The examples i provided above have loops.
