Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
Sabertooth Red Error Light
I seem to be having trouble with one of my Sabertooth/kangaroo motor controllers. The red error light is on and the the motor will not work. Up until now it has been working fine. I suspect what may have happened, (not sure if this is a thing or not), I had the motor/encoder unplugged from the sabertooth and had run the initiation script while testing other things on the robot. I have tried re-auto tuning but this does not help. How do I reset the red error light? Everything seems to be connected. I cant see an obvious reason for it not to work.
Steve
Hi Dave,
The delay in re-posting is mainly due to being really busy with home stuff and I haven't had much time to work on the robot. That and I am fast becoming really frustrated with this issue and I had already exhausted all known avenues over and over, (well, avenues that I, as an electrician can understand. Electronics are a bit of a mystery to me). I found myself having to walk away from it to collect my thoughts, calm down and try and think of something I hadn't already tried 20 times already, .......such as removing the speaker to see if magnetism is causing the issues. Thanks Dave, I'll give that a try. Why didn't I think of that? I've had issues in the past with EMF while working on the waist motor and the 240 volt fluorescent task light I was using to see.
Unfortunately I didn't save the original tune from when I was using the 2x12 Sabertooth, good Idea though.
I going to try removing the speaker right now and I will let you know how it goes
Thanks Dave, for all the help you've given me
Steve
tired Sorry to say Dave, but removing the speaker didn't work. Back to the drawing board I go....... tired
Steve
#43
Okay, let's stay on the EMF path for now. I see you have power cables running in the same conduit as kangaroos feedback wearing. Are the red and white wires the power fed to the radar motor? Try moving the power wires as far away from the feedback circuit as you can. Do this from the kangaroo all the way to the motor.
If you are able to start a tune with the motor out of the robot there's a reason why you can't start one when mounted in the robot. Something is keeping the feedback signal from getting back to the Kangaroo or causing it to be confused. The error message that the kangaroo shows is usually spot on on my experience. Trust me, I've caused most of them to trigger. Lol.
You said you tried to get a tune to start when you disconnected the limit switches and tried a Teach Tune? Did you get the same 6 flashes?
#44
Would twisting the signal pairs help prevent EMF like it does in Ethernet and long telephone line runs?
Yes Alan, great call. At the very least it couldn't hurt. I'd also twist the power wiring. Another method that could be tried is to wrap each signal wire around its own FERRITE ring.
#46
Are the signal wires free floating? They may require a pull up or pull down resistor - based on the type of sensor. Does the sensor have a pull resistor?
Thanks guys, I've been thinking that I may need to try running the motor power cables separately......all last night...Its keeps me awake at night. I kept putting it out of my mind because of the low current the motor draws and the fact the power and encoder wires are all together as a loom as they leave the motor. That and I'm a neat freak and I wanted everything all contained in one neat lead and plug. I think you are right though Dave, I have no choice but to pull it all apart..... again ;) and try with the motor power wires run separately. I have to head off to work now, so I will keep you posted. Thanks for so much for not giving up on me. :D Means so much to me and keeps me motivated.
Steve
Sorry DJ, missed you're post while I was typing the last one. There is no pull up or down resistor in the circuit. If required, where and how would that be connected?
