Hello, I tried using Robo Scratch for Android Mobiles today to program a loop. Is this possible at all? So I would like to start the scratch again and again.
Thank you
MPU6050 Accelerometer Gyro Temperature
— Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce
Thank you
You can find information about RoboScratch here: https://synthiam.com/Tutorials/Lesson/73?courseId=6
If you wish to use loops, you will use Blockly. Information is here: https://synthiam.com/Tutorials/Lesson/75?courseId=6
Today I finally tested Blockly. Allow me to ask you two questions?
"PlayAudio" dont work, I can not select audio files from the mobile device
"RGB Animate" does not work in Robo Scratch and Blockly.
Is the software error or am I doing something wrong?
Many Thanks from Germany
Sven
Play Audio works. If you cannot select audio file, it is because you do not have a soundboard. View the source code for additional information. there is a View Sourcecode button. Here is information about the Sound boards..
Soundboard (PC): https://synthiam.com/Tutorials/Help.aspx?id=44 Soudnboard (EZB): https://synthiam.com/Tutorials/Help.aspx?id=199
RGB animate works as well. RGB Animate only works if an RGB Animator is added to the project. View the source code for additional information. Here is information about RGB Animator: https://synthiam.com/Tutorials/Help.aspx?id=202
For more information, learn about ARC in the activity guide here: https://synthiam.com/Tutorials/Course/6
Additional information about ARC and controls can use the LEARN section accessed from the top of this website.
Hello DJ Sures, Thank you
Soundboard I had not, now it works.
RGB Animator I have in the project, in RoboScratch works fine, it does not work in the blockly. There is only one command:
You require animations in the animator to select. Press the question mark (?) on any control in the windows software to receive a manual about that control. Here is a direct link to the rgb animator control: https://synthiam.com/Tutorials/Help.aspx?id=202
I have 2 animations deposited, in RoboScratch I can select these Animations. In the Blockly not.
I believe the latest beta may include the Auto Position control commands. It should be available today
Hello DJ Sures, Soundbord PC dont work Soundboard EZB work
I will take Soundboard PC?
