Speech Recognition icon Speech Recognition — Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence. Try it →
Question For Dj About The Robot Arm
DJ....where can I get another one of the servo shoulder joint bearings? Did you have these installed or did it come from the manufacturer that way? The reason is; the existing wrist joint is far to weak. I would like to use another joint like the one used on the shoulder.
Thanks, Rex
Use the Contact Us and see if Alan can help you:) I don't know the answer to that question - but i'm curious of the answer!
Rgordan. Can you post pics of what your talking about. I might be able to find a bracket for you.;) Josh S
YEA be good to post a photo of it ,since i know so many many robotic websites selling them Also if its only a bearing and using it on a omnibot robot i did buy some thats a perfect tight fit inside the shoulder piece ,ID IS 1/4 inch,look at my omnibot 2000 project i have photos posted of it
this design can handle more then 100 lbs,but only using half,one reason to make a design handle double the weight is you save half the current,plus less stress on the motor my omnibot 2000 project
