Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
They will only rotate 165 degrees according to the datasheet.
Thanks for the quick reply
You can modify them to be continuous though , it is fairly simple.
what is the mod?
Unscrew the case , find the big pin on the main gear. Use a dremel to cut it off smooth to the gear. Put the top of the servo back together. Then the next step involves soldering a resistor in the bottom...
Ok, I have the pin removed. Where/how do I solder the resistor?
https://m.instructables.com/id/How-to-modify-a-servo-motor-for-continuous-rotatio/step2/How-to-modify-a-servo-motor-for-continuous-rotatio/
Here is one way which turns a servo into a gear motor but then must be powered by an h bridge....
https://www.seattlerobotics.org/guide/servohack.html
This is the most common version of a servo mod and it utilizes the original controller to power the servo without an external h bridge like the first mod i showed you.
Lastly there is a version where the potentiometer in the servo shaft is cut , then you position the pot into the dead center known as dead band and glue it in place.
Also, you can be modified continues servos directly from Servocity.com. I highly recommend them as one of the best places to get a nice mix of servos ar decent prices and always in stock.
