Possible use of Synthiam software and Ezb-4v2 on personal passenger drone
Possible Use Of Synthiam Software And Ezb-4V2 On Personal Passenger Drone
This is a reformated question. I have seen the use of the ezb-v3 control a small drone before, but with how advanced ez-robot software and flexibility the ezb-4v2 is, would it be possible with ez-robot software and the ezb-4v2 to be used as the central control system for a large passenger drone to control large hobbiest motor for both stability and for gps controlled flight capabilities, like for example the Ehang 184 or even a personal diy passenger drone of your own creation. I believe the awnser to be a simple yes, but has any one thought of or tryed this before with any success?
Quote:
central electronic control unit for a large passenger drone
I don't know if you are joking or being naive, EZ-Robot produces hardware for educational proposes. ASFAIK their products are not certified by the FAA https://www.faa.gov/aircraft/air_cert/design_approvals/air_software/ but you can contact them (EZ-Robot) and explain what you have in mind.
#2   — Edited
You are probably a kid based on the question and one long run on sentence, but I'll bite... Even if an ezb4 could do it, do you personally have the skill, materials, resources, engineers, lawyers and money needed to build the said vehicle? Then the business contacts in order to get it certified to fly with passengers?... How about you start with a little one that can fly maybe a Gerbil or Hampster first... (-;
Im 28 and im not joking or being naive, i should have worded it better, more like use in an ultralight aircraft built like passenger drone, that follows in all the regulations of faa, and if a guy on youtube can build a ultralight bi plane and passenger drone sliegh using the largest hobbiest motors and basic controllers, i just figured the ezb-4v2 could do the same.
#4   — Edited
you mentioned:
With or without passenger I think is a serious task, and If you are really located in the U.S.A. you should be careful what you put up in the SKY. If your "creation" hits someone or a someone's property you will be in really trouble. Using the justification I saw something in youtube maybe i can do the same... Is a interesting take.
Only to be clear EZBv4 is a glorified wireless micro-controller there is no "advanced" or "intelligence" built-in, all the logic runs in a computer / mobile device.
#5   — Edited
ptp is correct.... The ezb4 is just that, a hobbyist controller... What you need is a custom computer (not micro controller) with custom software and hardware (with interface). In addition the system will have to be seriously robust with built-in redundancies for safety...
#6   — Edited
I know the ezb-4v2 is a micro controller and it requires the ez-robot software to use it. I have a powerful enough computer to run the software at its max potential. i should have looked my post over and made sure it made sense before posting it, when i get excited over something some times i rush my posts along with out checkn them first. I reformated the question for a better way of understanding what im asking and talkn about.
#7   — Edited
OMG Richard R, I'm laughing so hard I'm crying and I think I peed a little. That was classic Richard R. Miss you man.
Quote:
You are probably a kid based on the question and one long run on sentence, but I'll bite... Even if an ezb4 could do it ".................................' How about you start with a little one that can fly maybe a Gerbil or Hampster first... (-;
Just like the old days. I love it when you pop in with your bits of wisdom. You have a way of speaking the truth and making things understandable at the same time.
J.I.R Kintobor, nice dream and imagination. I'm sure it can be done easily. However lot's of people would be concerned about large tractor size things losing control and falling out of the sky.
Thanks dave and yea i planned on flying the drone rather low with vent cover blade motors to avoid any accidents and implemet ez-robot software/hardware as well as secondary controller incase of any software malfunctions and toggle switchs systems as last resorts and also add some electric hub wheels to it as well to drive in on the streets as a low speed hybrid drone car. Ive created a simple concept design as of this moment using a premade fuselage and aluminum chassis with 8-12 motors, this photo is before i thought of the vented covers for the blades but you'll get the idea,
