Question. On the port D0 for example. There are red pins, black pins, and white pins. Which of these are Ground, Vcc, and signal.
thanks
Movement Joystick
— Analog joystick UI to control any ARC movement panel via mouse/touch-configurable dead zone, max speed, center-reset for smooth robot motion
thanks
Pretty self explanatory.... but here ya' go...
White = signal Black = ground Red = + power pin
red is positif.black negatif white signal
There is a section of the website called "Learn". You can see it from the top menu. There will be lots of information you will need to know in addition to your question. You will find tutorials and the datasheet. I recommend reviewing the datasheet.
Thanks for the help.
