Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
Pandorabot New Url?
Pandorabot New Url?
I was trying to add pandorabot control and it seems like it no longer works and the old URL is not working. Looks like they switched over to playground URL which you can log in and create chatbot. Maybe the ez robot control just needs to be updated to reflect playground.pandorabots.com URL? Anybody have any luck getting this to work lately?
Thanks, but site still won't load? It has to be playround url.
I'll look into it
Thanks for reply DJ. Maybe I'm missing something. I cant get to www.pandorabots.com at all, it wont load only https://playground.pandorabots.com/en/bot/ .The new ID now uses the form of username and bot name such as username/botID
From their FAQ
"What happened to the old site?
You can still access the old site and use the old services at www.pandorabots.com. However, we encourage you to shift over to the Playground or start using our Developer Portal and the Pandorabots API. We've added a ton of amazing new features and tools, including support for AIML 2.0, with even more exciting releases coming soon.
NOTE: Pandorabots is backwards compatible with AIML 1.0 (supported on the old platform), so you can easily upload your existing bots to the Playground."
I think it has fully switched to playground since old website won't load at all. I can log in to playground URL and create bot with the new username/bodID format but If i use that to edit the pandorabot control it won't work...see image. I would think the control needs to be directed to playground URL.
Can you load www.pandorabots.com at all...it hasn't worked for me for the past few days that I have tried to play with this control. confused
Please use the manual page as previously referenced. The pandora bot control works as designed. The information you are requesting is in the link of my previous response.
Please read the link and follow the instructions in the link.
Well the upside is I can now surf the internet and control ez-robot at the same time, client mode configured and ez-b controller and ARC both connected to network without problem:). The downside is pandorabot still won't connect...I have gone through both tutorials but again I can only create new bot in playground url and that wont connect. I'll just consider this a half victory and move on to another control.
